I have a older 32" TV with just a few HDMI ports its nothing fancy but it gets the job done. I would like to set it up as a smart TV by using a ONN HDMI Adapter I have had for a few years. I'm not to good at setting this kind of stuff up.
But here is what I would like to do if possible:
(1) I would like to connect multiple things to this device if possible I have 2 laptops both with Bluetooth and WiFi as well as a few cellphones I would like to connect to it as well. I even have a Alexa device I would like to hear over the TV if possible and I also have a older desktop tower which has WiFi adapter not built in WiFi.
(2) I would like to wall mount the TV so I'm trying to use as few wires and cables as possible.
(3) I plan to mount the TV above my desk bit kind of in the corner since this is a corner desk. So the distance from the laptops and the desktop will only be a few feet at most.
So what I want to know is what all can I expect to be able to do with this little device and can I do even half of what I'm trying to do?
Get a HDMI adapter for each device you have and connect them to the TV, If not enough HDMI ports on the TV get a HDMI splitter, most USB to HDMI adapters should work with your devices. If connecting wirelessly into HDMI is preferred there are devices out there as well just use google search.
Looking for a 4K 60fps HDMI Dolby 5.1 to PCM 5.1 HDMI converter
By VideoFanatic in forum Capturing and VCRReplies: 0Last Post: 25th Oct 2024, 10:13 -
Cable box > HDMI audio receiver > HDMI splitter > Capture card?
By ArianK in forum AudioReplies: 0Last Post: 6th May 2021, 04:18 -
S-VHS + HDMI upscaler + HDMI capture?
By Jupit0r in forum Capturing and VCRReplies: 2Last Post: 22nd Aug 2020, 03:00 -
VHS Player goes to no signal ONLY when connected to RCA to HDMI adapter
By spyjoshx in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2020, 17:51 -
DVI to Fiber HDMI with Powered Adapter
By cancolby in forum Newbie / General discussionsReplies: 8Last Post: 28th Jan 2020, 20:48
