How do I download this audio only?
[Attachment 83322 - Click to enlarge]
I don't want it to download Description the other audio because it is not correct
I do not want to download these audio files
| Description | ~02m24s
Results 1 to 9 of 9
use arrow keys up/down to select your audio, then hold space bar to select/deselect what you need
RE download only flush with X selection -
if not work for you, use arrow keys and space bar to select your prefer format
Assuming "Description" is the role value. You could try something like -sa role="":for=bestN_m3u8DL-RE --morehelp select-audio
More Help:
--select-audio
Select audio streams by regular expressions. ref --select-video
Examples:
# select all
-sa all
# select best eng audio
-sa lang=en:for=best
# select best 2, and language is ja or en
-sa lang="ja|en":for=best2
-sa role="main":for=best--[----->+<]>.++++++++++++.---.--------.
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
-da Description ???
How do I download the audio without Description ?
Aud *CENC audio_aac_1722369132080/und/mp4a/3 | 135 Kbps | mp4a.40.2 | eng | 2CH | 18 Segments | ~01m12s
Aud *CENC audio_aac_1722369554470/en/mp4a/3 | 136 Kbps | mp4a.40.2 | eng | 2CH | 1609 Segments | Description | ~01h47m22s
N_m3u8DL-RE Not Able to Download Stream
By Mochomo in forum Video Streaming DownloadingReplies: 50Last Post: 8th Apr 2025, 14:51 -
How to set download path while using N_m3u8DL-RE
By KingKongGotNoBalls in forum Newbie / General discussionsReplies: 6Last Post: 4th Oct 2024, 11:05 -
Download Multiple URLs with N_m3u8DL-RE
By HemaElqady in forum Video Streaming DownloadingReplies: 1Last Post: 18th May 2024, 01:21 -
Cannot download stream with streamlink or N_m3u8DL-RE
By JackED42 in forum Video Streaming DownloadingReplies: 5Last Post: 20th Mar 2023, 07:01 -
Espn Plus Download with N_m3u8DL-CLI
By Coledemon97 in forum Video Streaming DownloadingReplies: 2Last Post: 10th Jan 2023, 03:52
