I have been deinterlacing old DV footage with AVISynth an QTGMC and output an AVI format keeping as much data ass possible.
The format worked fine in older Premiere CS6 but with the new 2024 version, I get the media pending and the main monitor just freezes.
Any help? Any others having problem with new Premiere on various formats?
There are many many hours of footage, so I hope I don't need to deinterlace again..
MediaInfo outputs this info on the format:
General
Complete name : ----------------------------------------------------
Format : AVI
Format profile : OpenDML
File size : 48.4 GiB
Duration : 48 min 50 s
Overall bit rate : 142 Mb/s
Writing library : VirtualDub2 build 44282/release
Video
Format : FFV1
Format version : Version 3.4
Format settings, GOP : N=1
Codec ID : FFV1
Bit rate mode : Variable
Bit rate : 140 Mb/s
Width : 788 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 50.000 FPS
Color space : YUV
Chroma subsampling : 4:4:4
Bit depth : 10 bits
Scan type : Progressive
Compression mode : Lossless
Bits/(Pixel*Frame) : 6.180
Stream size : 47.8 GiB (99%)
coder_type : Range Coder
MaxSlicesCount : 4
ErrorDetectionType : Per slice
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 1
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 537 MiB (1%)
Alignment : Aligned on interleaves
Interleave, duration : 20 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Results 1 to 11 of 11
https://helpx.adobe.com/premiere-pro/using/supported-file-formats.html lists the supported formats.
If you need others you probably should look into plugins like https://www.autokroma.com/Influx which iirc is basically a libav wrapper,...users currently on my ignore list: deadrats, Stears555, marcorocchini -
My guess is that your old Premiere version was a 32-bit application which could use 32-bit VfW codecs, but your new version is most probably a 64-bit application which may require 64-bit versions of your VfW codecs installed to open videos in such a format; or an alternative codec plugin which does not rely on VfW codecs installed in your Windows system.
Ok thanks!
Two questions, before I commit to buy the Influx plugin:
IF the codec is the problem, would I still be able to play the files in windows using MPC with Klite mega which I have? Because that works fine.
The files seem to work first in Premiere, then they go pending. Preimere also goes incredibly slow when I import the files. Should it not warn for unsupported media instead? -
1. test it before you buy it
2. vfw and direct show filters are different things and MPC-XX comes with it's own decoders
The files seem to work first in Premiere, then they go pending. Preimere also goes incredibly slow when I import the files. Should it not warn for unsupported media instead?users currently on my ignore list: deadrats, Stears555, marcorocchini -
Ok so the problem has gone even more puzzling. I just remembered, I have used Premiere 2024 for deinterlaced DVD footage output to the exact same format. The only difference is a bit lower "overall bit rate: 112 Mb/s". And it works fine!
Any new thoughts?
Is the "Overall bit rate : 142 Mb/s" too high for premiere? -
No clue -> ask Premiere Support
widevineKeys-GUI v2 2024
By imr_saleh in forum Video Streaming DownloadingReplies: 83Last Post: 2nd Nov 2024, 06:24 -
Deinterlacing in 2024...
By wcndave2 in forum Capturing and VCRReplies: 146Last Post: 16th May 2024, 07:49 -
How to decrypt .ismv and .isma files in 2024?
By wojciech679 in forum Video Streaming DownloadingReplies: 11Last Post: 7th Feb 2024, 08:09 -
Premiere Pro & Uncompressed AVI - Which version to use??
By gs684 in forum Video ConversionReplies: 9Last Post: 4th Aug 2022, 22:52 -
Long (40 min +) AVI files created by Matrox RT.X2 in Premiere Pro CS5
By subwoofer in forum Video ConversionReplies: 56Last Post: 9th Dec 2020, 14:37
