Hi all~ just one quick question. when i use TPMGEnc, the default setting for NSTC SVCD is 480*480 (resolution) .... but my source is 720*480, will i be able to make the output the same resolution as my sources? and will it be playable if i still make it into a svcd?? thanks a bunch
If you make it as 480x480 it will look okey because the dvd player and also software dvd players "stretches" the picture to the correct aspect ratio(4:3).
If you make it as 720x480 you will make a XSVCD and it may not work properly on all players.
Which camcorder (newbie question)
By CliveJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 19th Aug 2011, 13:36 -
Newbie codec question
By fotoruss in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 22:47 -
Newbie question about learning
By Tundra Trout in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 18:41 -
Newbie question about cd music
By justalice in forum AudioReplies: 4Last Post: 7th Apr 2008, 20:08 -
Newbie Networking question
By karl333 in forum ComputerReplies: 1Last Post: 5th Mar 2008, 13:23
