Since the HiFi audio is embedded within the same section as the analog video of a VHS tape, would a TBC built into an SVHS recorder help with the occassional HiFi audio drop-outs?
TBC is just video.
Which raises the question what to do about HiFi audio dropouts, which usually come as clicks and pops.
Try manually adjusting video tracking but just for the cleanest HiFi audio. Sometimes a midway setting can be reached between picture and sound where both are clear. If not, we can optimise a capture for sound capture rather than picture, then substitute the better sound in the video editor.
For clicks, unsurprisingly a Declicker tool can remove or reduce many clicks. It's a common tool in digital audio editing and processing but for some reason seems mostly unknown to people working solely with video.Last edited by timtape; 31st Oct 2024 at 06:13.
How were those caused? If by gear, fix the gear. If in the signal, post-process.
So the tapes are misalign recorded? Misalign a deck to match. Be careful.Try manually adjusting video tracking but just for the cleanest HiFi audio. Sometimes a midway setting can be reached between picture and sound where both are clear. If not, we can optimise a capture for sound capture rather than picture, then substitute the better sound in the video editor.Want my help? Ask here! (not via PM!)
[QUOTE=lordsmurf;2756280] The tracking control is usually adjustable on the front panel of the VCR. If there's no marked "tracking" control, it can often be manually adjusted while a tape is playing using the up/down channel buttons on the VCR front panel or at the user remote control. Better still, look up your VCR's Owner's Manual. This is the first step I would take.
VCR - Is it possible to disable HiFi to Mono (Linear) switch for dropouts?
By useraxe in forum RestorationReplies: 13Last Post: 8th Jul 2024, 09:48 -
Panasonic NV-HS800 doesn't output video but does output HiFi audio
By golenman123 in forum RestorationReplies: 2Last Post: 15th Oct 2022, 15:49 -
HiFi Audio from old VHS tapes
By AstrAir in forum AudioReplies: 26Last Post: 18th Sep 2021, 07:37 -
Help request: Audio dropouts from bad recording
By Flyball1788 in forum AudioReplies: 8Last Post: 18th Aug 2021, 09:22 -
Mono VCR + HiFi VCR As Passthrough = HiFi Audio Out?
By companda in forum RestorationReplies: 7Last Post: 16th Feb 2021, 12:18
