While watching a football match on Sky Go I used to record my screen. But since this October they have changed something. The screen recording now has no video - only a black screen with audio. Tried several programs but none of them worked. Any help would be appreciated.
Unsure what you are using to capture but if it's OBS (Open Broadcaster Software), disabling Hardware Acceleration in Windows should fix it.
Code:https://obsproject.com/kb/hags
Thank you for your reply. I had installed OBS but it didn't start - there was only an endless looping. I will try again.
Tried again with OBS portable version and de-activated HW acceleration - didn't help. Still there's only audio and no video in the recording. But in the meantime found another prog that did the job correctly. So problem solved.
netblitz...can you tell us what that other program is?
Extraordinary claims require extraordinary evidence -Carl Sagan -
Much thanks.
OBS screen recording best results
By techmot in forum Capturing and VCRReplies: 2Last Post: 24th Jan 2023, 15:57 -
Screen recording software. Which one?
By voayer in forum Video Streaming DownloadingReplies: 8Last Post: 9th Jan 2022, 14:56 -
Screen Recording Problem!
By ten in forum Software PlayingReplies: 9Last Post: 9th Jan 2022, 11:26 -
ffmpeg screen recording
By qo4on in forum Video ConversionReplies: 0Last Post: 29th Dec 2021, 18:55 -
What is wrong with my screen recording?
By navarannan in forum Video Streaming DownloadingReplies: 32Last Post: 2nd Jun 2020, 11:36
