Hi! I had Panasonic DMR-E85H with which I recorded many DVD´s. Problem is that my Panasonic broke down maybe 10 years ago and after that I haven't been able to play those DVDs with other machine because they were unfinalized. Now after years I was going to think that I want same kind of machine somewhere so I can watch them and maybe do that finalizing also.. but quoestion is should it be that exactly same model (DMR-E85H) so I can play them or is it enoght that it´s only same brand? Example Panasonic DMR-E500H ?
You don't need to buy another DVD player or writer. There is a risk that they will not finalize your discs and that would be disappointing.
If you decide to buy a DVD player, then buy the same model DMR-E85H if you can find it.
I had the same problem few weeks ago and ordered Isobuster software.
It will not finalize your disks because the software isn't allowed to write to the disks. But you will be able to extract all the files on the disks (if none is corrupted).
Isobuster license costs $60. If the DVD player replacement costs less then it is up to you to decide which way to go.
The Isobuster trial will tell you what is on each disk but you will not be able to extract any files. -
ImgBurn has a "Close" feature That sometimes works.
Tools\Drive\Close.
Sometime Session works better than Disc depending on how the disc was written.
I have 3 different models of Magnavox & I believe they can finalize each others discs.
I would need to test to be certain since it has been a long time since I did not finalize a disc.
I do not know if it is the same with Panasonic. -
Any Panasonic DVDR should be able to finalize your discs, all Panasonics use the same operating system. Not that I'm not suggesting ISOBUSTER but if you prefer not to use a PC then just pickup any working Panasonic DVDR and you should be good to go.
Note pre '04 Panasonics won't have a thumbnail view, if that's important to you. A link to a thread listing the various N. American DVDRs.
https://www.avsforum.com/threads/panasonic-dvd-recorder-us-models-years-produced-and-f...tures.1134909/ -
usually i use a pioneer unit DVR 530H that is able to finalize Samsung, Pioneer, LG opened disks (no idea for panasonic because i have 3 units for this)
RIP Unfinalized DVD-RW Disc
By Subtitles in forum DVD RippingReplies: 5Last Post: 25th Dec 2023, 08:35 -
unfinalized miniDVD to youtube
By strix in forum DVD RippingReplies: 8Last Post: 11th Jul 2023, 09:19 -
Unfinalized mini DVDs in the camcorder
By Litaiff in forum Capturing and VCRReplies: 8Last Post: 12th Feb 2023, 03:56 -
Ripping unfinalized home DVD
By hkcj in forum DVD RippingReplies: 6Last Post: 8th Sep 2021, 02:13 -
2 Blu Ray Discs, 1 srt subtitle file, do I have to rip and merge both discs
By sethhuner in forum Blu-ray RippingReplies: 5Last Post: 27th Jun 2020, 10:24
