Sorry i'm still a newbie to all this. But one that has done a hell of a lot of reading (thanks out to all contributors) and wasted alot of cds testing. I'm not bitter about it, cause i sure am happy when i get the result i want.
Anyway, i don't understand why anyone would make a VCD or XVCD. Isn't MPEG-2 offer a better range of options for encoding (ie bitrates and encoding methods) that will work on most SVCD and DVD players?
As i've only been working on converting DIVX anime to SVCD so i can watch 'em on my tv instead of my little monitor, i'm probably missing the big picture (no pun intended). But i can't see ever needing to go outside the bitrates available for SVCD, why make an XSVCD?
Hi,
XSVCD only means a non standard SVCD. Meaning you can for instance also lower the bitrate or resolution to fit more minutes on a SVCD. For example you can make a XSVCD with a Dual channel audio track, SVCD Bitrates but VCD resolution encoded in MPEG2. This would create a disc than can hold far longer movies than a standard SVCD with dual audio.
Greet,
pSyChO DaD
The difference between genius and insanity is only measured by success !
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18 -
Patching SVCD to DVD question
By zanos in forum Authoring (DVD)Replies: 22Last Post: 29th Jun 2007, 10:17
