I'm wondering if certain common capture cards are known to "clip" whites or "crush" blacks if they are above or below a certain level? Seems like there are lots of posts identifying those faults after the fact in different capture samples.
My understanding is that some capture cards will still capture content outside of legal ranges, but I assume even those have limits on the high end in particular.
If a capture card has ideal automatic gain control, it would linearly scale down the entire waveform to get the brightest level to 100IRE so as to compress the dynamic range, but not to clip or crush high or low levels.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 1 of 1
ATI AIW Radeon 7500 AGP Capture Levels and Histogram in VirtualDub
By theseeker2 in forum Capturing and VCRReplies: 8Last Post: 3rd May 2023, 21:06 -
Are the levels of background noise too high for this VHS capture?
By Desve in forum AudioReplies: 44Last Post: 26th Jun 2022, 14:39 -
Adjusting capture card levels, not sure if it's right.
By ENunn in forum Capturing and VCRReplies: 57Last Post: 9th Jul 2021, 16:53 -
Capture Codec Setting, Crushed Black Levels, Histogram use
By Smells_Like_Feet in forum Capturing and VCRReplies: 8Last Post: 10th Aug 2020, 11:31 -
Adjusting IRE Black Levels with Sony DV Camcorder Pass-Through Capture
By VideoDoc in forum Capturing and VCRReplies: 8Last Post: 15th Apr 2020, 05:34
