Results 1 to 1 of 1
    Dec 2014
    I am editing three video clips and one audio clip. The video clips are 4K (3840x2160), PAL file format, 24 bits/25 fps variable frame rate with 48000 Hz/256 kbps audio. The audio clip is 48000 kHz, 16 bit stereo WAV file.
    Video was captured with Corel Video MultiCam capture. Audio was recorded using Audacity.
    In the multicam editor the video and audio are perfectly synced as I select between video cams. When I hit "OK" and it converts into a MultiCamXX.vsp file, the video and audio are no longer synced. I have tried quite a few fixes but nothing works.
    What can I do to keep the project synced for a final render?
    Let me know if you need additional project settings.
    Thank you, in advance, for any and all assistance.
