Basically I want to select multiple resolutions (for example 1080, 720, 480) in a single command for N_m3u8DL-RE
Currently I'm using this:
Can anyone help me with this?Code:command = f'N_m3u8DL-RE "{mpd_url}" --key "{key}" -sv res="{res}" -sa for=best --save-name "{output_name}" -M format=mkv:muxer=mkvmerge:bin_path="C\:\Program Files\MKVToolNix\mkvmerge.exe"'
Results 1 to 10 of 10
You can use the direction and space keys to select the desired resolution.Code:
N_m3u8DL-RE -mt -M format=mkv:muxer=mkvmerge --sub-format srt --use-shaka-packager --key (key) "mpd" --save-name "name"
Decrypting...
15:50:07.255 WARN : Aamis 2019 480.240.144p bengali zee5 WEB-DL x264 AAC2.mp4
15:50:07.256 WARN : Aamis 2019 480.240.144p bengali zee5 WEB-DL x264 AAC2.copy.mp4
15:50:07.263 WARN : Aamis 2019 480.240.144p bengali zee5 WEB-DL x264 AAC2.copy.copy.mp4
15:50:07.265 WARN : Aamis 2019 480.240.144p bengali zee5 WEB-DL x264 AAC2.hin.m4a
15:50:07.267 WARN : Muxing to Aamis 2019 480.240.144p bengali zee5 WEB-DL x264 AAC2.MUX.mkv
15:50:39.682 WARN : Cleaning files...
15:50:39.819 WARN : Rename to Aamis 2019 480.240.144p bengali zee5 WEB-DL x264 AAC2.mkv -
add resolution on N_m3u8DL-RE command
By whs912km in forum Video Streaming DownloadingReplies: 4Last Post: 21st Aug 2024, 08:23 -
how to force resolution to download with N_m3u8DL-CLI_v3.0.2?
By colebri in forum Video Streaming DownloadingReplies: 4Last Post: 6th Aug 2024, 09:05 -
N_m3u8DL-re - Command Advice Request
By geordie10 in forum Newbie / General discussionsReplies: 0Last Post: 28th Jun 2024, 07:48 -
N_m3u8DL-RE select specific video and audio track automatically
By josephsamual in forum Video Streaming DownloadingReplies: 4Last Post: 1st Jun 2024, 10:36 -
Download Multiple URLs with N_m3u8DL-RE
By HemaElqady in forum Video Streaming DownloadingReplies: 1Last Post: 18th May 2024, 02:21
