I have Sony Vegas 12. I have problems with colors when frameserving. That is: I load an mpg to Vegas. Do nothing, start frameserving it by Debugmode Frameserver. I open in Avisynth. I can see that the colors are different when I open the mpg directly in Avisynth. I loose some saturation if I frameserve from Vegas. You can see it on the photos:
Through Vegas:
[Attachment 83076 - Click to enlarge]
Directly from Avisynth:
[Attachment 83075 - Click to enlarge]
What do I do wrong? I notice this all the time I frameserve from Vegas. I frameserve with YUY2, the other options are RGB24 and 32 but they give no different results. The code is DirectShowSource ("Video.avi/mpg"). So I added no filters yet just opened the mpeg and the avi.
I don't know what your tools are doing. The levels are off quite a bit. Darks too high, brights too low
Vegas levels corrected:
Code:ImageSource("Vegas.JPG") converttoYV16(interlaced=true) crop(0,0,0,-1) levels(32,1.0,225,0,255,coring=false) turnright().histogram().turnleft()
[Attachment 83078 - Click to enlarge] -
You're using studio RGB in vegas - RGB Black reference level 16, White reference level 235 . But most other programs use "computer RGB" Reference Black = 0 , Reference White = 255
In older versions of vegas, the simplest solution is to add a levels filter (studio RGB to computer RGB preset) before you frameserve out
add a saturation condition to a glsl shader
By geextah_2 in forum Software PlayingReplies: 7Last Post: 5th May 2024, 04:59 -
Frameserving to Vegas Movie Studio or Vegas Pro
By stymie in forum Video ConversionReplies: 22Last Post: 5th Jan 2023, 23:58 -
Vapoursynth CPU saturation
By meimeiriver in forum EditingReplies: 4Last Post: 27th Jan 2022, 22:51 -
Random Saturation Issues on Transfer
By THX1136 in forum MacReplies: 11Last Post: 23rd Feb 2020, 20:49 -
Sony Vegas Sharpen Plugin....Vegas 10 amazing, Vegas 11 terrible?
By Blackout in forum RestorationReplies: 3Last Post: 16th Feb 2020, 12:48
