A GPT model suggested 15 Mbps for archiving HD footage and 25 Mbps for DV using x264. This seems backwards. Shouldn't HD require a higher bitrate?
Thanks.
GPT? "HD footage" ? DV ?
what is this source? Something direct from the camera? Blu-ray?
Native DV is already 25mbps.
What do you mean by "archive" ? -
Don't listen to AI. It's only able to rehash what it's been taught, and certainly in this instance it wasn't taught correctly.
Always archive at the best possible quality you can, remembering that you can't really get better than the original/source.
If you can manage it, archive lossless.
If you can't manage that, archive only slightly lossy using a DI format (prores, dnxhr, cineform, hqx...)
If you cant manage that, archive using a medium lossy, Intraframe codec (AVC Intra, MPEG2 Iframe/Imx, DV).
If none of those are comfortable for you (in which case, you must be very constrained for space), then archive at good QP/CRF AVC, HEVC interframe).
Again, if your source is already lower in bitrate than these archive formats, just archive your source.
Notice I didn't put numbers to them. Because you have to balance quality vs runtimes vs capacity, being mindful of whether you want to easily retain editability.
Scott -
Yes, I think your suggestion "Don't listen to AI" is relatable, especially for AI that we have in late 2024.
Devine - Modular Movie, TV, and Music Archival Software
By billybanana in forum Video Streaming DownloadingReplies: 1866Last Post: 19th Nov 2025, 22:57 -
Doubt media for archival large files
By patrion87 in forum MediaReplies: 6Last Post: 24th Oct 2023, 13:54 -
S-VHS tapes final format for archival
By Tek03 in forum Video ConversionReplies: 9Last Post: 16th Apr 2022, 06:54 -
Capturing For Archival Purposes - MiniDV/HDV
By ninlive in forum Capturing and VCRReplies: 1Last Post: 23rd Sep 2020, 03:35 -
file size/bitrate confusion, advice sought.
By super8rescue in forum Video ConversionReplies: 2Last Post: 16th Aug 2020, 12:03
