  1. I now have the option to get my mp4 video in H.265 (HEVC) and H.264 (AVC)
    This is 4k mp4
    I post process in Davinci which can accept just about any format ..... and crucially does all its editing & colour grading without touching the raw footage.
    At Render time I typically output (to date) in HD H264 is it's going on-line, and 4k H264 if it's going to be watched on TV or monitor.
    Am I better to capture in H265 with the benefits that brings and simply change to H264 at Render time, or stay with H264 right through the process ?
  2. Look at the specs, and more importantly - examine and test each option
    In theory HEVC should produce better results than AVC at similar bitrates. But is the device using similar bitrates ?
    Sometimes a device will have low bitrate or some other quality issues for one of the options. Often it's well know issues - users in that devices' discussion forum might say stay away from using "xyz" and post comparisions
  3. Originally Posted by Tafflad View Post
    Depends on many factors but with H.265 in theory you can have 10 bit per component where H.264 probably will be limited to 8 bit per component...
    Mar 2011
    Nova Scotia, Canada
    HEVC is better optimized for lower bit rates than AVC. Most decent HEVC encoding guides I've seen suggest that if you go for a CRF below 16 in HEVC when encoding you may as well use AVC.
  5. Thnx
    Aug 2018
    Wrocław
    And HEVC is generally intended for high resolutions (>=4k).
  7. OK then it’s H264 for HD and H265 for 4K
