Does the drive show up properly in the Device Manager?
(Can also look in MSinfo32 /components/problem devices)
Also check the Device Manager for errors, USB, Portable Devices, DVD/CD Rom Drives, etc.
Take a look to see if anything is mentioned for lower or upper filter drivers -
ImgBurn/tools/filter driver load order
If's possible try the unit on a second PC.
Results 31 to 40 of 40
I have not looked for complaints about the OP's optical drive.
Since you found several it appears this drive has problems.
I posted about one of my enclosures to show that some enclosures can be a problem.
I also would like to know the model of the enclosure so maybe the chip could be determined.
A computer USB ports may have enough power for a USB enclosure.
That would depend on the power supply of the computer.
If the power supply wattage is just barely able to run the computer it may not have enough left to power an enclosure with optical drive.
This is my own experience with using USB power for a device:
I have a small HDD powered only by USB.
It works fine with my computer but it will not play on my TV or settop BD player USB.
It won't even light up to show it is being powered.
The HDD I use most of the time for this is in an external enclosure that is powered with a wall wart.
It works fine.
The point is the USB power may or may not be enough. -
Hello everyone. Here is the video for the enclosure I bought. From the shop online.
https://www.transfernow.net/en/bld?utm_source=20241108d97Fp6O7
Been busy these past few days. -
I have not, nor will not, download this video - you could have uploaded that as an attachment to a reply.
Even then that is NOT what was asked for. You purchsed the enclosure online. All that is asked for >> The online link to the shop and the item which should go in to detail about it. -
Well if this is what you bought..
1. You paid far too much for it. Similar one are for sale at appr. $35 and do claim to write meia.
2. I have looked it up that unit's specs and I see no dvd writing capabilities (although it mentions 8x) A CD writer, yes. A dvd reader,yes. -
This is a link for a manual for this drive.
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://advdownload....a7gcJZ_Ula3Ugd
It supports what DB83 posted.
I would return this drive for a refund if possible.
This is my best enclosure:
https://www.amazon.com/Vantec-NST-536S3-BK-NexStar-External-Enclosure/dp/B01MRUN0HQ?th=1
Then buy a regular size optical drive to install in it.
I'm not going to recommend a brand for the optical drive.
There are many good brands & most people have their own opinions.Last edited by cholla; 11th Nov 2024 at 11:45.
Thank you everyone. Unfortunately for me, I somehow can't ask the seller for a refund. But I would buy a new one instead. Can you give me some recommendations in which I can burn DVD instead?
Edit: NexStar is unfortunately unaffordable for me at the moment. -
I can probably point you to some but since my drives are internal I could not recc. one.
Also we do not know you location. Little point in suggesting a unit from a US site (even Fleabay) if you are based in another country and vice-versa
Two BD-R discs had issues while burning or verifying with external BD drive
By Perene in forum DVD & Blu-ray WritersReplies: 0Last Post: 4th Apr 2024, 13:00 -
Unexpected reading errors when burning a cd
By Marcial in forum DVD RippingReplies: 5Last Post: 20th Feb 2024, 12:05 -
Tips on burning data to Verbatim BD-R M-Discs
By guy24s in forum DVD & Blu-ray WritersReplies: 7Last Post: 8th Jan 2022, 05:45 -
2 Blu Ray Discs, 1 srt subtitle file, do I have to rip and merge both discs
By sethhuner in forum Blu-ray RippingReplies: 5Last Post: 27th Jun 2020, 11:24 -
What is best way to archive DVD-r discs
By jay1028 in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2020, 23:29
