Page 25 of 28
FirstFirst ... 15 23 24 25 26 27 ... LastLast
Results 721 to 750 of 812
    Sep 2005
    Darkest Peru
    I'm more confused why TubiTV is encrypted for him. I direct downloaded from that site yesterday using Jdownloader.
    May 2025
    Out their somewhere in the land of Kangaroos and Koalas.
    Originally Posted by doctorm View Post
    I'm more confused why TubiTV is encrypted for him. I direct downloaded the from that site yesterday using Jdownloader.
    Some things on Tubi are encrypted others are not.
  3. Originally Posted by LZAA View Post
    N_m3u8DL-RE -h -> --decryption-binary-path <PATH>
    Thank you for your response. I don't understand but hopefully he does.
    Sep 2005
    Darkest Peru
    I've run into some web-dl lately where the audio track is AAC adts format which is less compatible. Is there a tweak for that or do I have to run it through ffmpeg afterwards with
    -bsf:a aac_adtstoasc
  5. I got some good news from my friend he has gotten the N_m3u8DL-RE command to work with the way he has it set up. He figured out that he had not renamed his shaka-packer in his system variables and once he did that he tested it and it worked. So this is terrific for him. Thank you all for the instructions in this thread and to larley for this terrific program. I know the steps it saves as I have in the past went into Developer Tools and dug out this and dug out that and then worked on getting the right command for N_m3u8DL-RE. It takes quite a lot of time and can be frustrating but one feels like a real tekkie.
  6. Is there a way to get this working on mewatch.sg again?
  7. Hi, I need some help. I used to use widevine proxy by devlarley to get keys, but it no longer detects anything. I’m not sure if the website has changed something, but one thing I suspect is that my real CDM might be outdated. It was extracted from an old Samsung tablet running Android 7.1.1, and the Google Chrome version installed on it is from 2023. On DevLarley's website, it shows the Widevine CDM version as 4.2.
    Sep 2005
    Darkest Peru
    Hmm. It used to be easy enough to grab these, but ABC TV seems to have gotten more difficult.
    https://abc.com/movies-and-specials/6348fcfe-241b-408a-8755-85bd07af9e8b
    WVP2 doesn't see anything, at least with L3. Considering it's an OTA station and 720p is the max resolution, you wouldn't think it'd be that bad.
    Any suggestions?
  9. I'm getting the following error message when I try to play the videos:
    "message":"Please open in Google Chrome browser to watch this video."
    I tried Firefox, Chrome, Brave all without success.
  10. Originally Posted by doctorm View Post
    Any suggestions?
    WVP2 works fine
    N_m3u8DL-RE "https://content-dtci.uplynk.com/ext/d874124ecca24c88a3c9575e78686acf/4b2c90bc4d7744b6b55be1bd2e683cef.mpd?cqs=LXiAuxHY7P-oykktptSKYs0yJgv9dhWTNu1hdkrKEfORvKfr_9Pwpjz9W6cLKP6vLb3EMvoKbMWcOGqbaIP7XiitSNgWCjV5SdUNq08tHB96cmsO8BRyQkt_smUwbaa3oRW9iOYda7Ft7qmjoa-p8XrJOH5WDk1UEwxkmhgKpsMUfYFGtJiGWFGdmHN7VnVyxzNls0nyIt9wCfX0Am1kdn_ka-RhN-OiHFT3uIGbh7dM1gRpOszNRQdvU_8-fGk0qnCtU3powxCP9gxXO3OPBhDLN_NSeLDdfN9IQXj7Q1uSy7D3cJePkDsE6so7MzUvTSU7AwKDjT1iOREFMlS4FIqFf0G96ZOUgjNYOBsSKNQ11eUXeT9Fp5NXM0LcwgI5o-rprjhal9SqbzkHH-bKIY-XgBa75KBAwxKtgM7v64Zgejz_zsE5LpY02S8GWYQUlFbchRLftOCdm6hZrb5-f5chOliYy5lZzL17xXbHO-eDGsKdm7Fum9iCIyknWVrSoaU6KdJ0o0jPk7mqxC_Gk26pR4W69AH36QsWcrj0cwfac2ew_brwUeiXr2X6nDiIoVH9mrhzxxthqX3JfDIsaU6XmAA6KV_kJWuVpSR-Yv4=&kid=4098a6a720374bfcbb4e362b652bcd51" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:145.0) Gecko/20100101 Firefox/145.0" -H "Accept: */*" -H "Origin: https://abc.com" -H "Referer: https://abc.com/" --key d5797093cd564265a5a592af18a852e0:03ac6212ab8c226d77e4c0aa7a916a77 --use-shaka-packager -M format=mkv
    Sep 2005
    Darkest Peru
    Any suggestions?
    WVP2 works fine
    Your post doesn't work for me. I get a 403 error. There is a scene release now in 1080p, so I'll go with that. Thanks.
  12. This is amazing, and a total game changer for me - thanks!
    Suggestion is there a way to perhaps build an API which is able to export the correct N_m3u8DL-RE command so that this be intergrated into other tools
  13. How does one clear the json log file? Without removing and reinstalling the addon?
  14. Originally Posted by paul92 View Post
    I just go to the Logs folder and every so often select the log files and delete them. So far no problems have come from doing that.
  15. cmd:
    echo.>"Path to \User Data\Default\Local Extension Settings\xxxxxxxxxx\yyyyyy.log"
  16. You know a way to download in batch, without open every single video?
    So I have some url about some video, and from command line, get key, manifesf pssh etc, to download, without using chrome.
  17. URL?
    If it is not supported by any of the many downloaders here in the forum (Devine and derivates like Envied, widefrog, UK Free to Air downloader, Ozvine, yt-dlp-mp4decrypt) then you'll likely have to code it yourself...
  18. Originally Posted by Obo View Post
    URL?
    The website is supported with: WidevineProxy2 Extension
    But my question is: you know how to do it in cli? Because I have a lot of url, and open them one by one , in the browser to copy and paste the command, to download with N_.... It's a long process
  19. As I said: if it is not supported by any of the CLI downloaders, you're at your own. The reason for this is that almost every website requires different handling. There is no standard. Look e.g. at all the different extractors written for yt-dlp (it's "extractor" folder has more than 1000 files, each usually responsible for handling ONE website). The same holds for widefrog, Devine and all the other downloaders.
  20. Originally Posted by Obo View Post
    Yes I know, I can create a script by myself, I have already all URLs.
    I just looking something, where from an URL of a video, get:
    PSSH
    Key
    Manifest
    So I can create for every URL, the N_m3u8DL-RE, to download.
    Image Attached Images
  21. Originally Posted by LZAA View Post
    Url?
    URL about what? video that i wish to download?
    I can download with this extension, is not this the issue, from the screen as you can see, i can download with this extension.
    I just looking for something to process URL in batch, so i can download without open url video one by one in the browser and copy and paste the N_m3u8DL-RE command , inside the extension.
  23. Originally Posted by LZAA View Post
    Url?
    please can you give me more details? I don't understand which url you mean
  24. Originally Posted by LZAA View Post
    you need this ?
    https://play.discoveryplus.com/video/watch/f2779cb6-da91-4357-9ad4-15b0906ecf73/13410f4a-1b0a-45c5-af67-ac33449721d7
  25. You won't be able to do what you want with WidevineProxy2 Extension.
  26. Originally Posted by LZAA View Post
    Yes i saw it. Maybe is required a L1 key?
  27. Originally Posted by faccta View Post
    you need this ?
    There are modules for vinetrimmer, but they are difficult to find. It is easier to find them for devine/unschackle/envied here on the site, although I have not been able to get them to work, and they work with playready to get 1080p.
  28. Hi, I just set this up and it's working perfectly for some videos, but for some I only get the first 9 seconds, any idea what I need to do differently for those?
  29. Originally Posted by Goku73 View Post
    you need this ?
    I tried envied and unschackle , but with Discovery+ Italy doesn't works. And streamlabs make me crazy because works very bad. I guess that there isn't a way for now. But with these app, discovery + in other countries, works. Only for Italy....
