Results 1 to 12 of 12
Thread: Ffmpeg could not be opened
  1. #1
    I downloaded several versions of the program - from the official site and from here. I extract the compressed folder but every time when I try to open ffmpeg.exe it can not run or run for a second then spontaneously program's window closes. I did a lot of things: change different folder for extracting, turn off Microsoft Defender smart screen, customize exploit protection for the entire folder (switched off all protections), add exclusion from Microsoft Defender Antivirus scans. Nothing helps. Sometimes when I try to open the app, popped up the message that I'll post here. What to do?Image
    [Attachment 83013 - Click to enlarge]
    Member
    Mar 2008
    Posts
    7,600
    Re: Ffmpeg could not be opened
    FFplay.exe is a command line program, it doesn't have a graphical interface.
    Secondly, smartscreen in Windows Defender has not recognized the program and has blocked it.
    This is based on the files "reputation" and doesn't mean it's infected wth malware.
    Member
    Feb 2006
    Posts
    2,843
    Quote Originally Posted by Maximilian Goof View Post
    did you click on the words "more info"
    you should see the words "run anyway"
    Quote Originally Posted by october262 View Post
    Yes, I saw "run anyway" but doesn't help. Also I know that this particular screenshot refers to ffplay but the same message popped up 2-3 times with ffmpeg.
    Member
    Feb 2006
    Posts
    2,843
    did you try right clicking on ffmpeg.exe and selecting "run as administrator"
    Yes I did. Nothing happened.
    Member
    Mar 2008
    Posts
    7,600
    Those programs do not open a window, they're meant for running at the command line
    (As I mentioned above)
    Member
    Sep 2008
    Posts
    4,890
    open commandline (windows+r then cmd then enter) or write script using ffmpeg - this how you work with ffmpeg - alternatively you can use some ffmpeg frontend (gui)
    Tank you! I will try this later.
    Member
    Sep 2008
    Posts
    4,890
    If i can recommend something - use script way - ffmpeg is designed to act not in interactive way but to execute sequence of parameters - you can pass those parameters in commandline but this is painful way - scripts offer only practical way to use ffmpeg.
    Member cholla's Avatar
    Oct 2010
    USA
    Posts
    785
    @ Maximilian Goof,
    I do not believe you are ready to use ffmpeg from command line .
    Try a ffmpeg GUI like Clever.
    This YouTube video should help you understand.
    https://www.youtube.com/watch?v=2W4Z9_jwlgE
    I downloaded ffmpeg GUI version, more specific Shutter encoder. I'm still learning it. Will have more serious dive in when I have access to my desctop PC.
  1. "could not be opened for reading: open file error" on mkvmerge CLI
    By naoto89 in forum Newbie / General discussions
    Last Post: 15th Jun 2023, 10:57
  2. Error: The file 'MKV3D_3D.264' could not be opened for reading: end of file
    By xenomatic in forum Newbie / General discussions
    Last Post: 31st Dec 2021, 18:11
  3. Video is being opened by Avisynth's DirectShowSource, need to change that
    By Compositor in forum Newbie / General discussions
    Last Post: 22nd Jun 2021, 00:13
  4. PotPlayer exits silently after settings were opened
    By Miamy in forum Software Playing
    Last Post: 26th Mar 2021, 04:02
  5. Replies: 0
    Last Post: 3rd Nov 2019, 12:31
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
