I'm trying to get my sisters firefox to show a taskbar icon after its selected but there's no icon,firefox does run but she want to have a few icons so she can select her page,iv'e tried a few things like deleting the iconcache.db,anyone know the fix for this issue?
try these tips -
If Firefox is not showing taskbar icons, you can try these steps:
Check full screen mode
If Firefox is in full screen mode, the taskbar will be hidden. You can use the F11 key to toggle full screen mode on and off.
Check the settings file
The settings file that stores window dimensions might be corrupted. You can try renaming the settings file.
Check taskbar settings
On Windows 10 or Windows 11, you can check which icons appear on the taskbar by going to Settings > Personalization > Taskbar. From there, you can turn icons on or off.
You can also pin Firefox to the taskbar by following these steps:
Click the Windows menu button in the taskbar
Click the arrow next to All Apps
Hover over the app you want to pin
Right-click on it and select Pin to taskbar
or try - Restart Firefox: Close and reopen Firefox to see if the issue resolves. Clear Icon Cache: Delete IconCache. db in C:\Users\YourUsername\AppData\Local and restart your computer. Create New Shortcut: Make a new Firefox shortcut on your desktop, then pin it to the taskbar -
Tried all those,when i click on firefox shortcut on the desktop the icon shows up,just not when i click on the quick access bar shortcut.
try what's in this reddit thread - https://www.reddit.com/r/firefox/comments/kl0j1l/firefox_icon_blank_in_windows_taskbar_and_start/
Didn't fix it,most likely it's a windows issue since it does the same thing with other programs on the quick access bar,just that firefox is what my sister uses the most.
I'm using Windows 7 & it is just a right click on the desktop icon & select "Pin to Taskbar" .
I doubt you sister is using Windows 7 So probably no help.
PotPlayer's Enhanced Taskbar Features
By credsr in forum Software PlayingReplies: 0Last Post: 12th Jul 2024, 16:36 -
Recent folders on Windows 7 taskbar don't show anymore.
By Litaiff in forum ComputerReplies: 1Last Post: 17th Jun 2023, 05:38 -
Annoying names preview on taskbar
By adamf154 in forum ComputerReplies: 2Last Post: 29th Oct 2020, 22:10 -
PotPlayer: Customize buttons in taskbar thumbnail?
By Unknow0059 in forum Software PlayingReplies: 0Last Post: 29th Sep 2020, 04:12 -
Lock icons
By olbluvw in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2020, 20:01
