I'm trying to get an MKV file to play on my PS4 Pro, but can't seem to figure it out. I just checked and the PS4 Pro can play MKV files, but only "H.264/MPEG-4 AVC High Profile Level 4.2 format"
My question is...how do I do that ? I looked and it is in H.264....but what about AVC ? I would like to keep the original file because I know that if I convert it to MP4, wouldn't it lose quality ?
I know that the PS4 Pro can't play H.265, which after some digging, is what the video is. Can I convert that to H.264 ?
I'm using handbrake.
Results 1 to 30 of 81
Think about this. Once bread becomes toast, you can't make it back into bread. -
Does PS4 play files at 4k resolution? Not according to this:
https://www.videoconverterfactory.com/tips/ps4-video-formats.html
Use HB and convert it to 1080p -
That doesn't do anything. It keeps telling me that -i isn't recognized as an internal or external command, operable program or batch file.
-i A Christmas Carol (1999) 4K Upscale AI.mkv -c copy output.mp4
-i A Christmas Carol (1999) 4K Upscale AI.mkv -c A Christmas Carol (1999) 4K Upscale AI.mp4
What am I doing wrong ?
This is just maddening. I just tried something else....ffmpeg -i A Christmas Carol (1999) 4K Upscale AI.mkv -vcodec copy -acodec copy A Christmas Carol (1999) 4K Upscale AI. mp4
All that happens is that I get this...
Error opening input: No such file or directory
Error opening input file A.
Error opening input files: No such file or directory
I'm done. I will just never get this movie to play on my playstation...Last edited by Spottedfeather; 22nd Oct 2024 at 12:58.
If you read what i said 'till you get a ps that plays h265' which means in the future,but as stated the file is only h264.
Your video is already AVC:
H.264 is AVC, so this is already ok, but the profile of your video is main, level 4 but should be high, level 4.2.Format : AVC
Format profile : Main@L4
So you need to recode your video with this specifications. -
1. Paste the MediaInfo report from your original MKV file. From what you pasted it looks like it's AVC. AVC=H264.
2. You won't keep the original quality, at most you can keep it at say 98%. And I've already given the command
(ffmpeg -i source.mkv -preset slower -crf 17 -c:a copy output.mp4)
You should get a file about 60-70% bigger than mkv. If you get bigger, it means that the quality of mkv is not that good... -
Don't really have much of a choice. I don't have hundreds of dollars to spend. And if I did, I'd get a PS5...
Formatting SSDs in PC as Mac
By dellsam34 in forum ComputerReplies: 20Last Post: 3rd Nov 2024, 22:27 -
Can’t play discs with BD Rebuilder’s quickplay menu on PS4
By TenPen in forum Authoring (Blu-ray)Replies: 0Last Post: 26th Sep 2024, 13:39 -
Txt2sup ignores italics formatting
By spiritgumm in forum SubtitleReplies: 16Last Post: 30th Jul 2024, 03:36 -
yt-dlp file formatting
By Jay123210599 in forum Video Streaming DownloadingReplies: 6Last Post: 22nd Nov 2023, 07:02 -
BD-RE discs on PS4
By younso in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Jul 2020, 03:43
