I'm working on a project that requires syncing text with audio or video files. I've tried using Subtitle Edit, but I'm unable to get it to work automatically. It seems I have to manually adjust the timings. I'm also aware of Pictory, but it's a bit pricey for my budget.
Does anyone know of a free or more affordable software or online service that can automatically analyze audio or video files, match the spoken words to corresponding text, and create timing information similar to an SRT file?
Any suggestions or recommendations would be greatly appreciated.
Results 1 to 15 of 15
Thanks for helping me out, "Subtitles"! I appreciate the suggestion, but I actually want to sync my own pre-written text file with the audio, not use AI-generated transcriptions. I’ve tried tools like DaVinci Resolve, which can do audio-to-text, but due to my accent, it introduces a lot of errors. So, I prefer to use my own text file and have the software match it to the audio. Yes, i have xtx 7900 gpu and rxt 3070 also 32gb ram all good. whisper ai is transcribing not taking my given text file.
What I’m looking for is a system that can recognize the speech in the audio, match it with the corresponding lines from my text file, and then create approximate timings for the SRT file. I don’t want the software to transcribe the audio itself, as the AI often misinterprets my pronunciation, and that leads to errors—misspelled words or missing text—which doesn’t look good in the final video.
I know "Subtitle Edit" has an auto-sync feature, but for some reason, I couldn't get it to work. It keeps giving me an error saying the start line has to be before the end line, even though I’ve set it up correctly. I eventually gave up on it.
I also tried Aegisub, but it doesn’t have auto-sync like Pictory does, so I have to manually adjust the timings, which can take hours. Since I’m just starting out, I can’t afford more than $5-$10, and Pictory’s $40 price tag is out of my budget, even though its sync feature is perfect.
Any suggestions for a free or affordable alternative that can automatically sync my text file with the audio would be really appreciated!
My Requirements:
looking for a tool that can:
Sync a pre-written text file with an audio file.
Match spoken words to corresponding lines in the text file.
Automatically generate SRT subtitles with accurate timing.
Work effectively with accents and pronunciations.
Be affordable. -
My Requirements:
Be affordable. -
And i would prefer a software or online service instead of a github python app , as i dont know python, and now i have no time left to learn, as busy in my own video recordings . so any service which can take this load of me to match my audio file to text file will save me hours.
Thanks .... i am stuck from days. Wasting hours in research. pls guide me. thanks -
@innerk thanks for clarifying what you actually need. This is more challenging than what I thought at first.
If Pictory can do exactly what you want, then you should look for alternatives.
I looked at such a list and they are not free. On YouTube there is mention of a free alternative using CapCut and TTS Open AI for voiceovers.
https://www.youtube.com/watch?v=uRf7GXrZZqU
Personally I wouldn't use an AI generated voiceover, it would make the audio less realistic. Even with an accent, it can be more interesting and authentic.
Hope this helps. -
Yes, Subtitles, thanks for the input. Just to clarify, I’m not using AI to generate the voiceover—I’m using my own voice recordings. The issue is that, due to my accent, tools like DaVinci Resolve often misinterpret the audio when generating text, so instead of relying on transcription, I need a system that syncs my pre-written text file with the voiceover. My goal is to provide DaVinci with an accurate .srt file that matches my recorded voiceover to the text I already have.
I’ve found several Python-based software tools on GitHub for analyzing voice, but I haven’t found anything that works smoothly on Windows without needing to learn Python, and I’m feeling really stuck because of it. Any help with automating this process would be a huge time-saver -
I haven't used Da Vinci Resolve to do audio to text transcription. It is possible that Whisper AI can do a much better job.
You are welcome to PM me with an audio file and I will gladly transcribe it for you so that you can see if you can get less errors.
Please include also the text file that you have written. Thanks. -
Thanks for the help, but it's not just one file. I create 2-3 videos a day, so getting one file done won't solve the long-term issue. I really need something like Subtitle Edit where you can provide both the audio file and the text file, and it recognizes the words to automatically create the timings, rather than doing it manually from the provided text. But I really appreciate your offer! Thank you so much.
I can't afford to buying $40 of pictory service of auto sync audio to text... really need something cheaper.... -
You are welcome.
What I meant was to test the transcription using Whisper AI and see how it compares to Da Vinci Resolve (Which does not have the best audio-to-text feature in my humble opinion). If the results are good then just install Whisper AI which is absolutely free. You have a good GPU so that should give you a huge benefit. I strongly believe that accurate transcription is the right solution for your project.
The offer still stands. Just PM me an audio file download link, Da Vinci Resolve created file and your text file.
Just curious, is the audio language in English or another language that is supported by Da Vinci Resolve? -
I have been using SubSync for years. It is a little tool that does a really good job the majority of the time. It is no longer being developed but it works great as is and I used it almost every day since most of my movies are recorded from Cable and if they don't have decent subs I have to sync ones from DVDs or Blu-Rays and this program does the job. It's free and easy to use.
https://subsync.online/ -
For synchronizing subtitles with multiple timing drifts, (a slightly more complicated task than SubSync is built for) I’ve had a mixed amount of success with ALASS (Automatic Language-Agnostic Subtitle Synchronization) on GitHub.
It’s a command-line tool that takes an incorrectly-timed subtitle file and a video file (with audio, naturally) as inputs and then outputs a synchronized subtitle based on timings interpreted from the video.
usage:
Also, if you’re comfortable compiling (I’m not) and a long, drawn-out manual installation process (no again) and manually managing dependencies (nope) including, but not limited to a Perl installation (make it stop please), CCAligner (also on GitHub) looks like it might have all the features you’re looking for, and it’s free.Code:alass.bat movie.mp4 IncorrectSubtitle.srt NewlySynchronizedOutputSubtitle.srt
@Simon_Haddad
Thank you for the information and example for alass.
I find it very useful for syncing subs.
Syncing Audio from One Video to Another, Possible?
By maveric in forum Newbie / General discussionsReplies: 2Last Post: 21st Dec 2022, 13:39 -
Audio to text? Forign audio to text then to English?
By ChasVideo in forum AudioReplies: 0Last Post: 8th Jul 2022, 11:23 -
Syncing an audio track with comparing two audio tracks of another language
By Ninelpienel in forum AudioReplies: 5Last Post: 24th May 2022, 19:39 -
syncing an audio track to the video?
By DiodE in forum AudioReplies: 4Last Post: 13th Oct 2021, 20:49 -
FREE motion interpolation solution (Uplavnyalka), pixel shaders
By DanilaZabiaka in forum Newbie / General discussionsReplies: 6Last Post: 18th Oct 2020, 10:54
