Hi,
please can someone help a cat?
I have an input MXF source with 8 audio monotrack (IN.MXF) this
https://www.swisstransfer.com/d/657054c8-ebc3-464d-9b7b-443c50dde13b
with:
CH1=britney spears audio content
CH2= rondo veneziano audio content
CH3= another music
CH4= another music again
please ignore CH3 and CH4 and all the rest, consider only the first 2 audio channels: britney and rondo.
I need to generate an output .wav (or a .mov) file so that
CH1= content the mixDown of CH1+CH2 source = britney+rondo panpotted audio
CH2= content the mixDown of CH1+CH2 source = britney+rondo panpotted audio
CH3= only britney
CH4= only rondo
need to preserve max audio quality in the transcoding process
video not needed
how can I do? thanks
I do something like this but there is a redundant usage I thinkCode:
ffmpegOCT2024.exe -y -vn -i in.mxf -filter_complex "[0:1] [0:2] amerge" -c:a pcm_s24le -ar 48000 temp1.wav ffmpeg2014.exe -y -vn -i in.mxf -i temp1.wav -af "pan=stereo:c0<c0+c1:c1<c0+c1" -c:a pcm_s24le -ar 48000 temp2.wav ren temp1.wav tempAudio_PAIR2_ForFFmbc.wav ffmbc.exe -threads 8 -y -i in.mxf -i temp2.wav -i temp1.wav -tff -target xdcamhd422 -vcodec copy -an "%cd%\%~n1_daR1mxf_aMXF_4CanaliAudio_Primi2Mixati_Secondi2Separati.MXF" -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:0:0:0:1:0 -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 1:0:1:0:2:0 -acodec pcm_s24le -ar 48000
How to record audio clip from online video?
By mikehende in forum AudioReplies: 6Last Post: 19th Feb 2022, 12:24 -
[Avisynth] Gradually transition from clip A to clip B with a “wipe” effect
By abolibibelot in forum Video ConversionReplies: 6Last Post: 31st Oct 2021, 10:47 -
Audio Clip Download
By biferi in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2021, 13:53 -
Can this audio clip be repaired further?
By dabbdubb in forum AudioReplies: 0Last Post: 7th Jan 2021, 18:59 -
how to re-add original audio delay back into a 2-inputfile ffmpeg transcode
By hydra3333 in forum Newbie / General discussionsReplies: 0Last Post: 30th Jul 2020, 02:30
