Hello
I have some large Wav audio files i need to reduce without quality loss to mp3. Can anyone tell me the best free audio compressor available?
There is no such conversion as "lossless" .mp3.
You can usually create good quality .mp3s if you have a good audio file to start with.
If the .wavs you have sound good then they should be a good source.
I usually use dbPoweramp for conversion.
I have the free version 10.1 & I set it up many years ago.
It is version 10.1 & no longer available.
dbPoweramp does have a 21 day free trial & it is supposed to have full function for the trial.
I have not tested this though.
For others:
EAC can convert to a good quality .mp3 if you have the CD to rip from.
foobar2000 can also convert but not as many settings.
Audacity can also do this.
ffmpeg or with a ffmpeg GUI named Clever. -
If you need lossless compression then use lossless codec for example FLAC, MP3 is lossy codec as such there is not possible to encode PCM into mp3 losslessly.
Other good free audio converters:
fre:ac : https://www.videohelp.com/software/fre-ac
Lame XP: https://www.videohelp.com/software/LameXP
Best Image Compressor
By Jay123210599 in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2024, 22:14 -
best video compressor/convertor
By natty in forum Newbie / General discussionsReplies: 26Last Post: 13th Nov 2020, 10:06 -
Help to Find Best Video Compressor
By Yamiraan in forum Video ConversionReplies: 4Last Post: 8th Nov 2020, 16:45 -
FCP > Compressor > .img (uncompressed .wav audio)
By willndmb in forum MacReplies: 0Last Post: 15th Aug 2020, 20:00 -
Compressor 3.5.3 Multicore Use
By celloben in forum EditingReplies: 0Last Post: 5th Jun 2020, 12:07
