Hello all,
I'm trying to convert a 1hour of NTSC-DV to fit on a 700mb file. Is there a good and precise why to do it whithout changing the resolution and maintaining a good quality ?
Here below is a previous post where I described how I tried to do it and did not work as planned.
http://forum.vcdhelp.com/viewtopic.php?t=90400&highlight=costi
Thanks for any idea you may have!
Regards,
Costi
costimm,
Your simple question has the kicker of "not changing the resolution". That would require an awful lot of compression (in my opinion).
I would take the DV and encode it with TMPGenc as VCD using 1500 video bitrate. The hour will fit, and result should look good on a DVD player. -
1 houre of DV fit in a 700 mb CDR/CDRW in VCD format.
of course you must to loos a litle quality and size.
use TMPGEnc Motion search precision: Highest quality,and check soften block noice. its a very aceptable quality..
800mb avi; Would want it to go onto a 700mb CD
By mark63534 in forum Newbie / General discussionsReplies: 39Last Post: 28th Feb 2010, 20:31 -
How do I make a 700MB+ video file to a 700MB video file?
By riahc3 in forum Newbie / General discussionsReplies: 26Last Post: 2nd Jul 2009, 21:55 -
how to rip 1.4 gb file to 700mb
By stranzer in forum Video ConversionReplies: 15Last Post: 17th Jun 2008, 17:17 -
700MB before subs, 1.12GB after??
By tommy23 in forum SubtitleReplies: 6Last Post: 17th Oct 2007, 23:05 -
cannot make 700mb rips
By zakkwyldebls in forum DVD RippingReplies: 6Last Post: 9th May 2007, 23:43
