Results 1 to 9 of 9
    May 2011
    See especially the roof of that stage. The video is interlaced and has 4:2:2 chroma subsampling. After deinterlacing with QTGMC those aliasing artifacts are still noticeable. I think it could be a sampling issue. Any ideas how to get the best result besides using an antialiasing filter like Santiag (I tried TurnRight().Santiag().TurnLeft())? On a side note, should I save the video as 4:2:2 or 4:2:0?
  2. Did you try 'Very Slow' as QTGMC preset? (iirc one of the parameters that changed between 'Slower' and 'Very Slow' helped with that,...)
    Depends on what you are planning to do with it.
    users currently on my ignore list: deadrats, Stears555
    May 2011
    1. I usually use the Slow parameter, more exactly QTGMC(Preset="Slow", FPSDivisor=1, MatchPreset="Slow", Sharpness=0.5). I'm gonna give it a try with Very Slow.
    2. It's a show recording for my personal library.
  4. 2. It's a show recording for my personal library.
    Assuming that means you might want to do something with it at a later on, I would keep the color sampling unless hardware decoding is necessary. (then you might even upconvert it to 4:4:4, since that often has better support than 4:2:2)
  5. The problem is the video is way over sharpened. Try something like:
    LWLibavVideoSource("sample.mkv")
    QTGMC(preset="very slow", Sharpness=0.0)
    Santiag(3,1)
    Still some buzzing though.
  6. Yeah, applying an additional QTGMC with InputType=3 and more aggressive AA can help a bit, some flickering can also be removed with masked denoising,... question is when the effort is not worth the result anymore
    May 2011
    Santiag(3,1)
    Thanks. But something strange happened: the image became much darker (with or without the Santiag filter). It seems that Very Slow preset triggers that. Do you have any idea why? I'm using the latest Avisynth+ and I installed the latest versions of all required tools for QTGMC.
  8. Originally Posted by elektro View Post
    Possibly an old or conflicting version of masktools2 or mvtools2 . Check your plugins directory and clean it out
    You can use avsinfotool to help identify versions
    May 2011
    Thanks. I found the problem: QTGMC.avsi was out of date.
