Is any method or button to reset factory settings on Sony VCR? My vcr Sony is doing the same error after auto rewinding the tape and the tape can not be ejected, and the machine keeps the tape even tho, not showing the tape-in status
Usually with a vcr, just unplug it from the power for a day or two,
long enough for any residual energy to drain -
Resetting the system parameters is usually held by a coin cell battery, If not, the parameters don't take days to reset, as soon as you unplug it it resets itself. Having said that, the problem you are facing has nothing to do with all this, You may have a bad cassette detection sensor, If you have the repair skills check the sensor and try to clean its contacts by some contact cleaner such as Deoxit.
Just try to get some fluid into the contacts somehow, There is no perfect way of doing it, It requires some repair skills as I've already mentioned.
Panasonic NV-HS960 reset settings after disconnect power
By prodarek in forum RestorationReplies: 3Last Post: 4th Feb 2022, 07:44 -
how to reset potplayer to play comercial dvd after update changes settings
By Vanlife in forum Software PlayingReplies: 1Last Post: 12th Oct 2020, 20:23 -
Format factory settings for Kenwood car stereo videos
By Drew200 in forum Video ConversionReplies: 1Last Post: 27th Jul 2020, 08:35 -
Format factory settings for car stereo pioneer avh
By Jozzy in forum Video ConversionReplies: 0Last Post: 23rd Jul 2020, 22:35 -
A Blu-Ray player & VCR connected together, VCR input settings?
By Kzzrn in forum Newbie / General discussionsReplies: 6Last Post: 28th Dec 2019, 11:15
