I've worked on some 4K footage and I'm wondering about the best bitrate to archive it.
My work was: extracted each frame and sharpened it using Topaz Photo-something, so that is sort of AI-sharpened. Then, I recombined the frames into a single video with VirtualDub2. The resulting video have a bitrate of 188 Mbps.
Should I reduce the bitrate for archiving, or is this a reasonable value for 4K with such sharpening? Thanks.
Results 1 to 1 of 1
Preserving DV Quality: GPT's Suggestion of 25Mbps for Archiving
By taigi in forum Capturing and VCRReplies: 6Last Post: 26th Dec 2024, 14:52 -
Preserving VHS Quality: GPT's Suggestion of 12Mbps for Archiving
By taigi in forum Capturing and VCRReplies: 3Last Post: 12th Oct 2024, 15:20 -
Stretch audio and correct pitch preserving quality (ffmpeg, audacity or..?)
By precipizio in forum AudioReplies: 0Last Post: 25th Feb 2022, 11:44 -
Deinterlacing DVD source while preserving the maximum quality possible.
By dopethrone in forum Newbie / General discussionsReplies: 24Last Post: 20th Feb 2022, 00:54 -
Best way to reduce DVD artifacts while preserving details?
By GlitchBob in forum RestorationReplies: 12Last Post: 2nd Jun 2021, 01:18
