I am trying to capture video with the Dazzle Hollywood Bridge on a fast Dell under xp. I have tried several video sources, two different capture sortward programs and two different Bridges. I invariably get a narrow band of distored video at the bottom edge and on the second Bridge also at the left edge. Can someone tell me if these are hardware issues, driver issues, or whatever? Otherwise the sound and video look excellent, but this artifact is too annoying to keep the product unless I can find a fix. Any suggestions would be most welcome!
By left and lower edge do you mean at horizontal disturbance across the bottom half of your video?
Is this present if you capture live video? or only on tapes?
Some videos don't record correctly and you appear to get a kind of horizontal bar at the bottom of footage on playback.
You could try clipping this with filters in virtual dub or your capture program?
Do you have any other information? -
This is normal just clip it off.
Craig
A constant yellow stripe on the left edge of DV-cap?
By Gew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Aug 2009, 06:49 -
Dazzle Hollywood DV Grounding Fix
By mk2000 in forum Capturing and VCRReplies: 6Last Post: 15th Apr 2009, 08:20 -
Captured video has pixel noise on top edge of display
By cohoman in forum Capturing and VCRReplies: 0Last Post: 23rd Feb 2008, 18:32 -
16:9 picture lower edge above the black border flickers on 4:3 TV
By Srivas in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 12:15 -
Edge artifacts noise caused by transitions/dissolve effects.
By baculus in forum EditingReplies: 6Last Post: 25th Jun 2007, 17:07
