Im trying to convert an AVI file to MP4 however the audio is always low pitched and sounds slightly crackly.
The camcorder I used is a Sony DCR-TRV130E and I have imported the footage from a mini dv tape via firewire to a 2009 macbook pro running windows 7 32bit.
The AVI file plays back perfectly with no issues at all but when converting it to an MP4 using handbrake the audio messes up and sounds low pitched and crackly.
I have a few mini DV tapes and almost all of them have the same problem when converting the AVI file to MP4.
All of the audio settings on handbrake are on default. I have tried changing them but previously but nothing has worked.
I'm not sure what to do here as I am a newbie to importing mini DV footage any help would be appreciated
Results 1 to 18 of 18
Here is the mediainfo report
Complete name : D:\TAPES\Mini DV Tapes\7.avi
Format : AVI
Commercial name : DVCAM
Format profile : OpenDML
File size : 8.62 GiB
Duration : 42 min 44 s
Overall bit rate mode : Constant
Overall bit rate : 28.9 Mb/s
Frame rate : 25.000 FPS
Video
Format : DV
Bit rate mode : Constant
Bit rate : 24.4 Mb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Time code of first frame : 00:00:00:01
Time code source : Subcode time code
Stream size : 8.60 GiB (100%)
Audio #1
Format : PCM
Format settings : Big / Signed
Muxing mode : DV
Muxing mode, more info : Muxed in Video #1
Bit rate : 768 kb/s
Channel(s) : 2 channels
Sampling rate : 32.0 kHz
Bit depth : 12 bits
Stream size : 235 MiB (3%)
Audio #2
Format : PCM
Muxing mode : DV
Bit rate : 768 kb/s
Bit depth : 12 bits
Stream size : 235 MiB (3%) -
Pcm audio is incompatible with the mp4 container.
It must therefore be recoded. A lossless option for mp4 would be flac.
Other lossy options are ac3 or eac3. -
So should I use FFMPEG to encode the AVI files?
I also thought id mention there are 14 avi files alltogether and 2 of them did have perfect audio when encoding to mp4 however the rest do not.
And on one of the MP4 files the audio is bad in the first half of the video then it works perfectly once the scene changes in the next half of the video. -
If you can use a .mkv instead of an .mp4 you could give mkvtoolnix a try.
Just open your .avi file & select "Start Multiplexing".
The process is very fast.
It may or may not fix the problem. -
You could extract a problematic audiostream, upload it to a hoster and post the download link here.
So we can take a look and find a solution.
To extract the stream you can use clever FFmpeg-GUI.
Load your avi, click main page, click extract streams, select only the wanted audiostream and deselect all others, the click extract.
You'll find the wav file in your target folder. -
I have attatched the audio streams from the AVI file. I have reduced the first audio file to roughly 30 seconds to reduce file size
The second one is 3 seconds long -
The audio is 41 seconds. If the video section was only 30 seconds, it's a possibility the sample rate is wrong.
Is this correct? I can't tell with this music
(resampled to 44100 samples per second - now it's 30 seconds)
Done in Audacity
https://manual.audacityteam.org/man/audio_track_dropdown_menu.htmlLast edited by davexnet; 15th Oct 2024 at 13:17.
Sorry mkvtoolnix did not work for you.
I do not have many .avi files.
I tested mkvtoolnix with two & both loaded.
I opened the "7_1_pcm_s16le.wav" you posted with mkvtoolnix.
This is the .mka file it created.
That means mkvtoolnix will work with the audio in the .wav format you posted.
Looking at the MediaInfo in post #3.
Yours shows this:
Video
Format : DV
The .AIV I tested with shows these:
#1 AVI
Video
Format : MPEG-4 Visual
#2 AVI
Video
Format : Cinepak
I believe the DV format may be the problem.Last edited by cholla; 15th Oct 2024 at 12:10.
Perhaps look at the file with DVDate, see if it produces any useful info.
If it's type 1, convert it to type 2 - Then MKVToolnix should handle it properly
https://www.videohelp.com/software/DVdate -
I created a .dv file per instructions I found at forum.videohelp.com.
I looked at it with DVDate .
It created a Type 2.
This opened fine in MKVToolnix.
This may be the difference:
DVCAM is a professional-grade video recording format and trademark of Sony that was introduced in 1996:
Features: DVCAM uses a 15 µm track pitch, which is 50% wider than the DV format. This allows for frame-accurate editing and reduces recording time by one third. DVCAM also uses locked audio to prevent audio synchronization drift.Last edited by cholla; 15th Oct 2024 at 15:37.
Audio Sync Issue after Deinterlacing and Converting to MP4
By Bermuda1 in forum Video ConversionReplies: 51Last Post: 2nd Oct 2024, 07:47 -
Issue with unicode characters when encoding a subtitle file
By Hemer in forum SubtitleReplies: 1Last Post: 2nd Jul 2024, 05:33 -
handbrake minidv avi files to mp4 audio speed issue
By zeus winston in forum Video ConversionReplies: 3Last Post: 5th Mar 2024, 12:48 -
Encoding issue with staxrip audio.
By coolgit in forum Video ConversionReplies: 0Last Post: 22nd Nov 2022, 05:51 -
Embedding SCC subtitles into an MP4 file without re-encoding
By neilgd in forum SubtitleReplies: 15Last Post: 29th Mar 2022, 14:20
