:o any body tell me why the colour in my 23.976 divx falls to pieces after convertion, the colours are all out lots of purple
I got the exact same problem. The DivX file is good quality but when converted with tmpgenc the picture gets corny and on one file a lot of colour mismatches like purple. How can you fix this?
Try change the directshow reader priority under optional -> environmental setting -> vfapi plugin (right click on it add increase it to 2).
if that won't help try reinstall divx 3.11 and also maybe the new 4 and 5 divx codecs.
also try use the search function and search for purple...
Colour Conversion problems with Avisynth
By wiseant in forum Video ConversionReplies: 6Last Post: 16th Mar 2011, 11:40 -
Menu Colour
By sambat in forum Authoring (DVD)Replies: 0Last Post: 26th Apr 2010, 07:54 -
Problems with subtitle font and colour
By skp61 in forum SubtitleReplies: 5Last Post: 29th May 2009, 19:29 -
FFDShow Big Colour Problems
By Endemoniada in forum Software PlayingReplies: 3Last Post: 28th Feb 2008, 22:19 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 18:10
