to explain:
I have a widescreen display (2560x1440)
I am trying to screen record SD videos which are played at fullscreen, like from kanopy.
I want to record at 640x480.
It only makes sense to record in SD since some are older videos not available in higher resolution.
BUT, so far various screen recorders I have found just....don't do it properly.
Some, like NCH Debut screen recorder, when a specify a 640x480 resolution, interprets this by
recording the entire screen and then adding black bars at the top and bottom (resulting in black bars on all 4 sides)
Others just "squeeze" the video to that aspect ration.
Should this be complicated ?
All the program needs to do during the recording is ignore everything outside a 4:3 section in the middle of the display and
then downgrade the resolution.
Is there one that can ?
	OBS Studio:
 Setup: You can create a scene that captures only a 4:3 area of your screen. Set the canvas size to 640x480, then adjust the capture source to fit the desired section of your screen.
 Configuration: In the settings, ensure that the output resolution is set to 640x480, and you can adjust the scaling options to avoid distortion.
	Yeah I did try OBS and it sort of works, my issue with it though is why doesn't the capture window default to the center of the screen ?
 Does yours ?
 I kind of had to play around with the actual area it records in order to center it and I feel like you should only have to do that if you're trying to capture
 an area off-center.
 however it's a decent solution.
	another solution is use a simply ext like Stream Recorder, rip stream, and if you want 480p only you can re-encode with ffmpeg
	Angela v2.0? Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  Why is a WMV video played in imbalanced retio with PotPlayer?By Naoo in forum Software PlayingReplies: 0Last Post: 28th Apr 2022, 10:03
  how to download a video that is being played inside another application?By sagokey in forum Video Streaming DownloadingReplies: 9Last Post: 15th Feb 2022, 17:50
  VirtualDub2 - Display video pane on a secondary display?By simple in forum Video ConversionReplies: 0Last Post: 17th Sep 2021, 13:54
  Best video downloader for difficult sitesBy mol3000 in forum Video Streaming DownloadingReplies: 3Last Post: 27th Jul 2021, 05:38
  Difficult Decimation SourceBy ZacharyGeorgeNN in forum DVD RippingReplies: 5Last Post: 8th May 2021, 17:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
