    Oct 2016
    argentina
    I can't figure out what am I doing wrong with this. I already got these keys:
    0100ac7ed511383d2bd98cd4b7f3ca9b:be68c413f0e147f4cf8a50fd7c10b82f
    01017426a08b68d8994e653e518852dc:501c73870a58b68deab3409fd0e47d9c
    01025fcac2a83f24107fa102c6dbf6d5:ff8013a8da71c460f28e5942a1203ffe
    01053b2c9a3be879720b2e390ae14e79:00000000000000000000000000000000
    I use this command:
    N_m3u8DL-RE "https://akm.latam.prd.media.max.com/r/dash.mpd?f.audioCodec=heaac&f.audioTrack=en-US%7Cprogram&f.audioTrack=es-419%7Cprogram&f.audioTrack=pt-BR%7Cprogram&f.videoCodec=avc&r.duration=2616.013400&r.keymod=2&r.main=0&r.manifest=f335aa6f-2e26-4a43-b80f-39aaa0ca5c75%2F0_41ea1e.mpd&r.origin=cfc%7Cprd-wbd-latam-vod&x-wbd-tenant=beam&x-wbd-user-home-market=latam" -mt --use-shaka-packager --key 0100ac7ed511383d2bd98cd4b7f3ca9b:be68c413f0e147f4cf8a50fd7c10b82f --key 01017426a08b68d8994e653e518852dc:501c73870a58b68deab3409fd0e47d9c --key 01025fcac2a83f24107fa102c6dbf6d5:ff8013a8da71c460f28e5942a1203ffe --save-name test -M format=mkv
    I selected to download only the 720p video, all audios and all subtitles. I'm getting these errors:
    19:13:46.264 WARN : [h264 @ 00000167cd9c2040] top block unavailable for requested intra mode -1
    19:13:46.266 WARN : [h264 @ 00000167cd9c2040] error while decoding MB 2 0, bytestream 31643
    19:13:46.536 WARN : [aac @ 00000167cd9f1cc0] Reserved bit set.
    19:13:46.547 WARN : [aac @ 00000167cd9f1cc0] Number of bands (29) exceeds limit (9).
    19:13:46.596 WARN : [aac @ 00000167ce07b840] Reserved bit set.
    19:13:46.596 WARN : [aac @ 00000167ce07b840] Prediction is not allowed in AAC-LC.
    19:13:46.672 WARN : [aac @ 00000167ce0fdd40] Reserved bit set.
    19:13:46.672 WARN : [aac @ 00000167ce0fdd40] Number of bands (18) exceeds limit (12).
    Full log: https://mega.nz/file/huETyJIY#rahXHgxqtA4D0xHYEPVQ7QrprXpxOxKzFcmJ019ulA0
    Output file: https://we.tl/t-mNmuAYLFoH
    If you check it with mediainfo, they apparently are unencrypted, but still they are unplayable. At this point I'm not sure if they are corrupted, still encrypted, or what. I have also tried to download them with yt-dlp, decrypt them with mp4decrypt, but I had no luck either. I don't see where's my error, hope you can help me please to see where's my mistake, I want to learn. Thanks.
  2. KID: 0105dedd09907bcd24194d7ed1a9cf24
    KID: 0100455b76b15d9ef84a66c0037430f7
    where are the keys?
    Oct 2016
    argentina
    where are the keys?
    I don't understand... where or how did you get those KID's? I could only get the 4 indicated KID-KEY with WKS-KEYS.
  4. Banned
    Apr 2022
    Hong Kong
    Discussing paid videos is already against the rules.
    For @Frieren's reply, s/he is talking about those missing keys, because we can't find these key ids in what you gave us.
    And as for your question, try decrypting them manually or do not mux them beforehand, i.e. to download the video & audio, then decrypt them manually.
    Oct 2016
    argentina
    The KID:KEYS I provided have been obtained with WKS-KEYS, also the same results using the CDM-Project extension:
    [Attachment 82806 - Click to enlarge]
    [Attachment 82807 - Click to enlarge]
    I have inspected now the mpd and I found those KID's that Frieren said, anyway they don't show up in either WKS-KEYS or The CDM-project extension, so... I don't know how to continue.
    Oct 2016
    argentina
    Well I finally could solve it by myself . I'll leave it here in case anyone needs it.
    The problem is that for some reason (that I still don't understand), either when you use EME Logger or the CDM-Project extension, you get a wrong PSSH, which takes you to get a wrong KID-KEY pair, resulting in an unplayable video after decrypting.
    The solution is to inspect the mpd and find there the correct PSSH for the desired resolution, in my case, 720p. Take that new PSSH, use it in WKS-KEYS, and you'll get the real working keys:
    --key 0100455b76b15d9ef84a66c0037430f7:d2d2a4d6008ecf48565ddd15031d443c
    --key 0105dedd09907bcd24194d7ed1a9cf24:00000000000000000000000000000000
    --key 010211250d78038004aaee04019e2eca:44caf22e7d5c0cb6006ad838e2403e0f
    --key 01015d541dc206023c2d2789990e4a62:1319d4463d81d4a551cf5cf41b96658d
