For the screenshot in post #15 - in vdub2 (original version), audio=>full processing mode, audio=>conversion . But there is no option for 24bit , you can use float or 16bit
Results 31 to 50 of 50
I see, Never used it before that's why I didn't know about it, There is always a first time as they say.
Edit: To clarify about my earlier question about AVSPmod, I was just asking if there is a way I could do de-interlacing, cropping, resizing and converting to AVI all in one step but I realized that AVSPmod works differently than ffmpeg, I guess to save a step I will stick to vdub2 and take a hit on 8bit video, 32bit float for audio is not an issue for me.
You know what will be nice? If I can input the original quicktime footage into AVSPmod and do all the mentioned steps plus the trimming and change the audio at the output with vdub2, That would be single giant step.Last edited by dellsam34; 16th Oct 2024 at 01:29.
No luck here, I removed the components but still getting cannot open the file in AVSPmod.
What do you mean PDR's script in AVSPmod? It's a FFMPEG script not AVISynth.
Edit: I see which post you mentioned, Yes that did it for me, It opened, but that would have worked without installing quicktime though, I'll try to remove quicktime and see what happens.Last edited by dellsam34; 16th Oct 2024 at 03:15.
How do I use the script to point to a different folder, For some reason it picks the file HyperDeckS2 correctly without specifying where that file is but when I want to change to another folder I don't see where to specify the folder in the script.
Code:aud=LWLibavAudioSource("HyperDeckS2.mov") vid=LWLibavVideoSource("HyperDeckS2.mov") fl=aud.GetChannel(1) fr=aud.GetChannel(2) AudioDub(vid, MergeChannels(fl,fr))
Just put in the name, with full folder path. In Windows Explorer, right-click on the file and there should be an option to "Copy as Path".
Then put that into the script. Use the quotes as you show in your post 37# above eg
"D:\VideoHelp\Dellsam\HyperDeckS2.mov" -
The problem now is the loading time, few minutes so far and not loaded, We have to wait for PDR.
You expect it to take a few minutes because of the indexing time - that's mostly dependent on your storage speed, partially dependent on your CPU . Once the index is created, subsequent access should be "instant" , as long as you keep the index files. If you move or delete the index, it will have to re-index
Hence the prior comment on using LSmashVideoSource/LSmashAudioSource for MOV/MP4 files (instead of LWLibavVideoSource/LWLibavAudioSource) - no indexing - it should be "instant" . But for some reason there is an issue with that sample file - it wsa very laggy . You can check other files, maybe there was an issue with the one you uploaded -
Actually the sample I posted works fine due to its size, the bigger the size the longer it takes to load, 7 minutes into indexing for the full length tape and had to abort, I couldn't wait longer.
That info is about 15 years out of date . You can't believe everything you read
QTSource required quicktime to be installed, and it was for avisynth legacy , x86, did not support extended pixel formats (because old avisynth)
LSmash , FFMS2 , BestSource are source filters that use libavcodec / ffmpeg libraries to do the decoding independent of OS installed codecs . (The exception is when you enable HW acceleration, it requires HW drivers to be installed - e.g. if you use Nvidia CUVID to decode, it obviously requires a Nvidia card) -
Well, it wasn't that bad, it took about 10min to index into AVSPmod, once loaded I was able to do all the processing in AVSPmod and when export to vdub2 I was able to do the trimming, I'm pretty happy, thanks to everyone and especially PDR:
Code:aud=LWLibavAudioSource("D:\Capture0001.mov") vid=LWLibavVideoSource("D:\Capture0001.mov") fl=aud.GetChannel(1) fr=aud.GetChannel(2) AudioDub(vid, MergeChannels(fl,fr)) QTGMC(Preset="Faster") AssumeTFF() Crop(12, 6, -12, -6) LanczosResize(1440, 1080)
Code:General Complete name : D:\Title-Here.avi Format : AVI Format/Info : Audio Video Interleave Format profile : OpenDML Format settings : PcmWaveformat File size : 217 GiB Duration : 1 h 25 min Overall bit rate : 362 Mb/s Frame rate : 59.940 FPS Writing library : VirtualDub2 build 44282/release Video ID : 0 Format : HuffYUV Format version : Version 2 Codec ID : HFYU Duration : 1 h 25 min Bit rate : 360 Mb/s Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 4:3 Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 8 bits Scan type : Interlaced Bits/(Pixel*Frame) : 3.863 Stream size : 216 GiB (99%) Audio ID : 1 Format : PCM Format settings : Little / Signed Codec ID : 1 Duration : 1 h 25 min Bit rate mode : Constant Bit rate : 2 304 kb/s Channel(s) : 2 channels Sampling rate : 48.0 kHz Bit depth : 24 bits Stream size : 1.38 GiB (1%) Alignment : Aligned on interleaves Interleave, duration : 17 ms (1.00 video frame) Interleave, preload duration : 500 ms
Well, i did not kept track of everything here in this thread but i hope the field order did not got mixed up with all the conversions steps?
It's one step actually, But I visually check everything, this is why I like the AVSPmod/vdub combo.
FYI, during my failed attempt to point out that the new VDub 2.1 won't open this file whereas VDub 2.0 does, this FFMpeg code came up as a solution:
Code:ffmpeg -i "HyperDeckS2.mov" -af "channelmap=0|1:stereo" -c:v copy -c:a pcm_s24le "HyperDeckS2_fix.mov"
Converting from Lossless-Uncompressed to Lossless-Whatever
By Marvolo in forum Video ConversionReplies: 8Last Post: 8th Feb 2024, 13:20 -
lossless 4.2.0 video to lossless 4.2.2 - any issues?
By spicediver10191 in forum Video ConversionReplies: 21Last Post: 10th Jun 2023, 01:00 -
FFmpeg: Lossless video conversion from AVI to MP4 possible for ALL codecs ?
By pxstein in forum Video ConversionReplies: 1Last Post: 8th Feb 2022, 01:20 -
Quick sanity check: Lossless to lossless encoding HuffYUV to UTVideo
By nicholasserra in forum Video ConversionReplies: 2Last Post: 20th Aug 2020, 11:41 -
FFMPEG - hevc_nvenc & h264_nvenc lossless presets not truly lossless?
By AnomalyDetected in forum Video ConversionReplies: 5Last Post: 27th Oct 2019, 02:24
