I'm using AE 24.6.2, Media Encoder 24.6.1 and Premiere 24.6.1.
When I export, the output file always uses "Format profile: Base Media / Version 2" (according to MediaInfo). I think it matches one of the default Adobe presets - "H264 Match Render Settings 15Mbps".
It doesn't matter if I add the project to the "built in" render queue OR send it to Media Encoder. It also doesn't matter that my settings have been saved manually as templates/presets and selected before exporting. The only details that persist are the sequence settings (framerate etc.).
What's could be the cause of this?
				Results 1 to 1 of 1
  Shutter Encoder settingsBy timsky in forum Video ConversionReplies: 2Last Post: 11th Aug 2022, 18:02
  Problem in importing After Effects Composition in Premiere ProBy FireOnyx in forum Newbie / General discussionsReplies: 0Last Post: 19th Jul 2022, 16:17
  After Effects export through Media Encoder restricts bitrate issueBy Stile in forum Video ConversionReplies: 2Last Post: 17th Nov 2021, 15:52
  Looking for alternative to Premiere Pro and Media EncoderBy Waloshin in forum EditingReplies: 3Last Post: 31st Jan 2021, 04:18
  x264 PRO Plugin for Adobe Premiere/Media Encoder stopped workingBy Sithtronic in forum Video ConversionReplies: 4Last Post: 2nd Sep 2020, 10:10
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
