because decrypt key is quite difficult.
I want to directly record screen but how to remove watermark?
Results 1 to 30 of 30
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
putting watermark on a video should result in someone burning a
"a$$hole" mark into your forehead. -
[Attachment 82815 - Click to enlarge]
i am getting -
I edited on the fly and couldn't try after, my browser was blocked for some reason, no it's not working, probably because they are updating the position of elements ?
I implemented the same thing on my own (using part of their source code) and it works
You can see here "Video Player by aqzs" at the bottom when video is played.
[Attachment 82818 - Click to enlarge]
[Attachment 82819 - Click to enlarge] -
It blocked me too until I switched. Try using a proxy + changing browser. I think that debugging the code to see what happens when you pause it, might be ok, considering that the dynamic watermark is gone only then.
Turns out their watermark is a joke. You can get rid of it easily by editing the file and overwriting it
https://player.vdocipher.com/v2/index.js
Search for "Video license expired" and get rid of all the if logic blocks that crash the video player. Then go the dynamic html of the page (not the text resource) and search for the node canvas and delete it entirely (there should be only 1 annotation canvas). Then you can record with no privacy issues using obs studio. Here's a ~10 seconds demo
no_watermark_demo.mkv--[----->+<]>.++++++++++++.---.--------.
Hi,
Can you please let me know how exactly to remove watermark. Appreciate if there is step by step method or video that helps...
Thanks so much in advance
Aveni -
Here's a Chrome extension that will automatically disable it.
https://files.videohelp.com/u/311269/vdocipher_ext-v1.1.zipLast edited by solheh; 28th Jan 2026 at 15:43. Reason: New version
Thank you, @solheh! However, it appears that even after installing the extension, the watermark is still visible.
📹 VIDEO 2: Pexels Videos 1448735.mp4
MPD: https://cdn04.vdocipher.com/media/aWYD1JUhUz8sh/725eff64/stream.mpd
[BLOCKED] https://clipstat.com/api/v2/
[KEYS] --key 9ce83b7597ff56fbb479f911733d6f84:8cf44ce527d8a12fd f4b30796a9e837f --key de239f44ff785d0bb49dba711d8ba6ad:9402a07d38daac170 d9488056c2a8893 --key f190e152a276530580bfe38272c018d1:d5221889bcd74d6b3 0f00bd7140550d1 --key 35246032b7e35f5f84e17100f844eaf0:e8d51c378f81a11db 9061ae22a9b2ba1 -
try this new version: https://files.videohelp.com/u/311269/vdocipher_ext-v1.1.zip
Thanks so much dear @solheh ...It works amazing with one of the video providers, but for some reason, it doesn't operate with the other one. Is there something that needs adjusting in the file itself?
New vdocipher DRM
By aqzs in forum Video Streaming DownloadingReplies: 27Last Post: 2nd Apr 2025, 16:50 -
Vdocipher decryption
By HemaElqady in forum Video Streaming DownloadingReplies: 6Last Post: 1st Dec 2023, 12:53 -
help with vdocipher keys
By killua in forum Video Streaming DownloadingReplies: 2Last Post: 9th Oct 2023, 11:54 -
Download from Vdocipher!
By Goust in forum Video Streaming DownloadingReplies: 7Last Post: 19th May 2023, 05:51
