Downloaded both the installable and the portable versions of SMPlayer 24.5.0.
On starting SMPlayer get error message appearing -
[Attachment 82791 - Click to enlarge]
SMPlayer main window appears also (beneath the error message). Tried opening and playing videos, nothing happens. Videos don't play regardless if I use the installed or the portable versions of SMPlayer.
Running SMPlayer under Windows 7 64bit SP1.
Is SMPlayer (supposed to be) compatible with Windows 7? If so, then what is wrong with my SMPlayer installations?
According to this, it's Windows 8 and above
https://www.smplayer.info/en/download-windows -
https://github.com/smplayer-dev/smplayer/releases/download/v24.5.0/smplayer-24.5.0-win...6-unsigned.exe
(package for Windows XP and other 32-bit systems)
You can try this and see if it works. Seems like the developer of smplayer stopped 64bit versions being used for windows 7 a while back.
smplayer dev: "The mpv developers decided to stop supporting Windows 7, so now Windows 8 is required.
But you can still use the 32 bit package, it contains an old version of mpv."
This issue may be that developers decided to drop windows 7 support from MPV a while back which is what smplayer uses to drive its GUI, smplayer used to use mplayer back in the day and then moved onto MPV (used to be called mplayer2). -
https://sourceforge.net/projects/mpv-player-windows/files/64bit/mpv-x86_64-20240728-gi...12.7z/download
https://sourceforge.net/projects/mpv-player-windows/files/64bit-v3/mpv-x86_64-v3-20240...12.7z/download
Try either of these builds to see which one works for you. Saw a post where someone said MPV (2024-07-28) is last build to support Windows 7 but I have no way to truly test this out. I don't know if you have a newer cpu that can allow v3 version to work on your computer, but the regular version should work if it allows Windows 7 with older CPUs.
Another person said that this build worked on windows 7 64bit for them. Try it out and see for yourself.
https://sourceforge.net/projects/mpv-player-windows/files/64bit/mpv-x86_64-20240310-gi...ff.7z/download
Hope some of this helps you out.
Screensaver function is not working properly
By Mondriaan in forum Software PlayingReplies: 0Last Post: 18th Aug 2024, 14:19 -
AmarecTV isn't working properly
By ElmoRocks05 in forum Capturing and VCRReplies: 19Last Post: 3rd Nov 2023, 03:04 -
QTGMC not working properly (AviSynth+)
By JadHC in forum RestorationReplies: 12Last Post: 15th Feb 2023, 17:18 -
Vdub Not Working Properly
By dellsam34 in forum EditingReplies: 2Last Post: 17th Jan 2022, 21:05 -
Subtitle styles not working properly
By Kracov in forum SubtitleReplies: 2Last Post: 3rd Dec 2021, 08:29
