Hi there.
What file format is the best to save in when making short internet videos?
I make short 1 to 10 minute video clips for posting on the internet.
I'm looking for decent quality, along with a smaller file size.
Thanks.
Jenny
I would say a .avi file would work best. Depending on how you are planning on veiwing the file.
Avi is uncompressed, unless you use something like DiVX to code the avi, then it will be too big of a file.
Actually, I would have to say to try 160x120 mpg if you like quality. The file will be about 60% smaller then an uncompressed .avi.
If you want space, then try .rm (real media). I don't know right off the bat how much smaller it is then uncompressed avi, but I believe it's a lot less then avi and mpg. The biggest problem with this format is that you sacrifice quality for size.
Any which way, you are looking at a huge file. A compressed mpg of 160x120 of 1 minute will be anywhere in the ball park of 1,000-3,000KB or more. But, you can also use programs like Winzip and Winrar (I think that's the program) to compress the video file down a little more.My shameless plug - XavierEnterprises.net -
Thanks for the responses guys!
What do you think of wmv? Is that a good file type to use?
Are there any problems with it?
Thanks.
Jenny
need help finding the best container/codec Format for my situation
By staeberc in forum Video ConversionReplies: 7Last Post: 17th Feb 2011, 16:42 -
.dxa format file to other video format
By Edisonsss in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 16:52 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Strange situation regarding an AVI file
By hyphenate in forum Newbie / General discussionsReplies: 5Last Post: 11th Mar 2008, 10:02 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
