I asked wise GPT on the bitrate for archiving my VHS material (EasyCap->QTGMC, H264), and it suggested 12Mbps. I'm curious if this configuration is adequate. Any insights or recommendations on this would be highly valued! I intend to keep the original VHS cassettes, of course. Sorry, maybe this post isn't suitable for this sub-board.
The bitrate depends on the archive video format. If you want to archive your raw captures, it'll be in the order of 50Mb/sec for the standard lossless capture formats (HUFF, LAGS, UT). That's the preferable format: pure, un "molested" video, without even QTGMC applied.
The other scenarios? An MPEG 2 archive at 12Mb/sec is only just OK, apparently. And for MP4 eg H264/AVC, 12Mb/sec is good quality. The problem with these last two is that the video has been processed away from it's capture state, which means that if you want to do anything further with it later, your "master" is now somewhat of a lesser-master than the original capture.
A pristine lossless archive allows you to have the best quality for when you inevitably get better at restoration and want to have another crack at it. -
GPT? get real.
Stretch audio and correct pitch preserving quality (ffmpeg, audacity or..?)
By precipizio in forum AudioReplies: 0Last Post: 25th Feb 2022, 11:44 -
Deinterlacing DVD source while preserving the maximum quality possible.
By dopethrone in forum Newbie / General discussionsReplies: 24Last Post: 20th Feb 2022, 00:54 -
Archiving VHS Tapes to digital
By FelipeArchives in forum Capturing and VCRReplies: 4Last Post: 13th Jun 2021, 17:25 -
Vhs to dvd or vhs to pc for archiving
By braveheart3158 in forum Newbie / General discussionsReplies: 36Last Post: 21st Apr 2020, 11:06 -
Help - VHS to h.264, bit rate for archiving
By kamoo in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2020, 15:10
