  1. After you have authored with sprucce and it creates a image MyMovie.img to the hard drive can you then burn the image with nero as a ISO the burn from that DVD ISO to make copies?
    o(-_-)o---------------------------------------o(-_-)o
    May 2001
    Don't use the create "IMAGE" function. Use create "TITLE SET", instead. This will allow you to check the "pre-burned" version of your file with any computer DVD player to see if it is what you expect. If it is okay, then bring up NERO, select the DVD-Video template, then drag those files to the VIDEO_TS directory. Then burn and live happily everafter!
  3. Nice thanks
