Results 1 to 17 of 17
    Dec 2018
    Pakistan
    Hi, I have a large mp3 audio with 9 hours duration. It has so many songs in it and all songs have been spaced by 1 or 2 second silence in-between too. Yes I can manually separate and save each by select and save via audacity and other splitters etc but the problem is that I have around 70 such files. So kindly tell me some software which can automatically extract each song and save (even save by numbers 1, 2 , 3 shall do my job) Thanx in advance.
    Mar 2021
    Israel
    I doubt if there is an audio software that would do exactly what you are asking. Manual option is the only way to do such a job.
    I would start by using Audacity and put markers in those silent 1-2 seconds (either manual or use Audacity plugins) and then use Audacity to export individual sections between each markers.
    Another option I might try is to use audio-text generation so that I would know from the lyrics timestamps when each song finishes and next song starts. I would start by splitting the 9 hours into 9 one hour files (making sure each file ends in a song - you don't want to cut the last song in half). This will help the audio-text generation to deal with instead of a full 9 hours audio file. Generation of the lyrics can be an added advantage to your songs collection albums.
    Dec 2018
    Pakistan
    Thanx.. yes placing markers and extraction is definitely the last option.. There was some software perhaps Replay Music or some other name which used to detect silence between songs while recording from some streaming media websites like deezer etc.. May be someone here can develop a script or logic which Replay used .. Yes my case is not via streaming media as I have a file in my pc but the logic to detect silence may be used in a script if someone here can take interest.
    Dec 2018
    Pakistan
    audio-text generation possibly cant be applied here as the music in my file is non-English .. thanx for suggestion though.. Am sure it can help in english music to many members here who didnt pay attention towards this aspect.
    Mar 2021
    Israel
    Audio to text generation can be in any language. I use Whisper AI to create lyrics for Operas of 3 hours in any language
    You are welcome to send me one hour audio file download link and I will create the lyrics for you. PM is recommended. I need to know the songs language naturally assuming it is always the same language and not a mix of languages.
    Dec 2018
    Pakistan
    You may be right as I never tried it..nor it is needed here as first priority .. first I want to extract songs.. being a noob, in audacity plz let me know if we can select multiple pieces of this large file in one go (like marking various split points at silences and then shall audacity export all of them with just numbering even? OR you meant by selecting one piece at a time and saving as selection?
    Mar 2021
    Israel
    If you are not familiar with Audacity, I suggest you experiment with a small album like 5 0r 6 songs.
    Audacity has a lot of useful tools.
    For example generation of labels
    Analyze > Label Sounds >
    Fill in the minimum silence duration
    minimum label interval
    select Label type : Point before sound
    Label text : Sound ##1 (or any thing else more convenient to you)
    Apply
    Then
    Export Audio
    Export range : Multiple files
    I tested a short file and got 4 multiple files this way. see attached.
    Use the Audio Track 01-04.mp3 as the source.
  8. Such software exist - many years ago had similar problem - need to split many hour long mp3 automatically - for sure this was before 2008 so apologies but i don't remember name of this application (perhaps it was https://en.wikipedia.org/wiki/Mp3DirectCut?useskin=vector ) however you can try to test for example https://portableapps.com/apps/music_video/mp3splt-portable
    Dec 2018
    Pakistan
    Apply
    Then
    Export Audio
    Thanx a lot.. yes I'll definitely try it .. appreciate help.
    Dec 2018
    Pakistan
    yes.. exactly thats the one I need. I'll go for its Portable version and return here with feedback .. Help appreciated .. This forum never disappoints me .. Thanx to the admins here as well.
    Dec 2018
    Pakistan
    Also if someone can guide for the same silence detector splitter for mp4 songs plz..
    Mar 2021
    Israel
    mp4 is video. just extract the audio first and follow the above suggestions.
    Dec 2018
    Pakistan
    yes.. You are right.. Thanx but I do want to work on long mp4 files which do have silence between songs and if theres some mp4 splitter which can detect silence and extract video songs without encoding then it can help me.
    Mar 2021
    Israel
    I see. Well this can be a bit more complicated. Most video splitters cut either into specific number of segments or by specifying the time duration of each segment. What you really need is to split by timestamps.
    You need to prepare a csv file with the timestamps and then try this video splitter.
    https://github.com/frederikb/videosplit
    This is a command line software not GUI.
    To generate time stamps either do it manually and note down the time each song starts and then use the a.m. software or it might be more convenient using the extracted audio file as I suggested above and generate the timestamps using Audacity.
    This is just of the top of my head as it getting late here, but you might get more useful suggestions from other members.
    Apr 2007
    Australia
    Rats! I reread the thread fully. Subtitles has already told you. I've left it here anyhow.
    I tested with Audacity 3.4.2
    Open an audio file in Audacity
    Go to Analyze > Silence Finder
    -- Test which settings work best. There will be some trial and error.
    Apply.
    Go to File > Export > Export Audio
    -- Make sure to check Export Range/Multiple Files
    Select what destination, format/quality/etc. etc.....
    Export.
    It's not perfect, but pretty good.
    The output file sizes give an idea what didn't work correctly.
    You'll have to finish your work the hard way.
    Cheers.
    Last edited by pcspeak; 10th Oct 2024 at 20:19. Reason: Failed to thoroughly read the thread
  16. mp3DirectCut will do what you want. In order to test it, I made one large MP3 by combining an album's worth of files. You might have to fiddle with the settings a little, but open the MP3 and use the Special/Pause Detection menu. My album consisted of 10 individual songs, and therefore it'd require 9 split points. The default settings worked fine in this case, although I changed the cue offset to -2 frames so the split points are closer to the start of each track.
    Once you're happy, use the File/Save Split menu to save the individual tracks.
    mp3DirectCut will split the MP3 into individual tracks without re-encoding anything.
    Mar 2021
    Israel
    As I mentioned before, one way to split videos is to know the timestamps of the beginning of each song.
    Then create a chapter.txt file that is compatible with MKVToolnix GUI requirement and use it to do the splitting.
