---Why sometimes does a file that is converting always lock up at the same place? Is it a bad file? I also have Nero 5.5 burning software, it can convert to mpegs, it is very slow, but it also locks up on certain avi files at the same place everytime?
If it locks up at the same place on the same file. I would say it was a bad file. I just went through this and it was a bad file. It played OK, but when I tried to encoded it to mpeg it locked up at the same point everytime. It was a divx file. I checked it with divxfix. You can get it in the tools section to your left.
May the force be with you.
Problems converting MP4 to AVI
By Missmax in forum MacReplies: 3Last Post: 11th Mar 2012, 12:50 -
By Missmax in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2012, 14:40 -
converting existing vobs to mpegs
By lordhutt in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 25th Jul 2010, 04:42 -
can't open mpegs made over 5 years ago - used tmpg
By heidihagen in forum Authoring (VCD/SVCD)Replies: 3Last Post: 20th Mar 2009, 14:40 -
converting hd pal mpeg2 to hd ntsc mpegs
By gearo in forum DVD RippingReplies: 1Last Post: 3rd Nov 2007, 18:26
