hello,
I was curious if there is a way to record this live stream lossless without interruptions https://tbd.com/watch-live/
or if you would suggest just to screen capture it. As far as I know screen capturing is lossy and will probably generate dupes which affects the smoothness of the playback and overall would be a degeneration of the original quality.
An alternative would be to connect the hdmi out of my gpu to the hdmi in of my black magic capture card and record it in real time but through a lossless chain so to say. Never did that before and therefore have no idea if it would make sense or if it would generate dupes as well
thanks in advance for any clever suggestions
regards
Get m3u8 from the network tab in developers tool and use literally anything to download yt-dlp ffmpeg N-m3u8DL-Re hlsdl streamlinkCode:
https://content.uplynk.com/channel/1831163f97674328ad9f4b4814ed39c5.m3u8?tc=1&exp=1614631202&rn=614441536&ct=c&cid=1831163f97674328ad9f4b4814ed39c5&ad=comet&ad.adUnit=%2FTBD%2FLivestream_midroll&ad._debug=TBDNET_ssai_livestream_midroll&ad.ad_rule=1&ad.pmad=12&ad.output=xml_vmap1&sig=5d194a4e4c5a4d59023d6a39a2ba5ba82dcd817b615e9f82115c41d9b26ffd0a
discord=notaghost9997 -
streamlink "https://content.uplynk.com/channel/1831163f97674328ad9f4b4814ed39c5.m3u8?tc=1&exp=161 4631202&rn=614441536&ct=c&cid=1831163f97674328ad9f 4b4814ed39c5&ad=comet&ad.adUnit=%2FTBD%2FLivestrea m_midroll&ad._debug=TBDNET_ssai_livestream_midroll &ad.ad_rule=1&ad.pmad=12&ad.output=xml_vmap1&sig=5 d194a4e4c5a4d59023d6a39a2ba5ba82dcd817b615e9f82115 c41d9b26ffd0a" best -o video.ts
I went for streamlink and couldn't find an answer which made sense to me for
one question: If the stream has a short connection timeout or my internet has one will the batchfile attempt to re-connect and try to continue the recording?
How to use AmarecTV Live capture to stream in virtual camera
By Hamilthon in forum Capturing and VCRReplies: 0Last Post: 8th Jul 2024, 09:04 -
BBC Glastonbury Live Stream Capture
By ghostrewel in forum Video Streaming DownloadingReplies: 9Last Post: 16th Jun 2024, 09:10 -
Streaming decrypted live stream - live pipe buffering problem
By Kalisto in forum Video Streaming DownloadingReplies: 0Last Post: 25th Apr 2024, 13:19 -
How to capture this live stream.
By pedrothelion in forum Video Streaming DownloadingReplies: 4Last Post: 4th Jul 2021, 12:18 -
how to capture a facebook live stream (starts in an hour)
By olli66 in forum Video Streaming DownloadingReplies: 2Last Post: 4th Dec 2019, 06:49
