Can you help me with the error I encountered as a result of the mux made with mkvmerge?
The code I use
Code:N_m3u8DL-RE "https://gcp.blutv.com/5bd2f293ac08fb00066d2b88/outputs/629f22571aade80008c81c8f/v3/dash-0/output.mpd" --key 2837ebbdaf3457a890c4dfe00651613d:6364397245981d00a83dfddbe1490149 --key 4abe235985f65d899ddd445181091bff:dda0cb3e06b056ccbd3868e78f19d4dd --key bb145633e4ff565b92c29fa1b9ede12d:b43c56c860c6d43e0a1fe2497ca8d461 --key 002829c360d05835890aeb86b77e0fcf:c23706dd3c9d9e3cb56e2aca24cf7db6 --key 7b91b2045c0c5295be14ebfec9d805d6:dd60e5786eb63bcdd6ba6f1e98d71f2e --save-name movie1 -M format=mkv:muxer=mkvmerge![]()
Results 1 to 11 of 11
Try with -M format=mkv instead of mkvmerge. The default will use ffmpeg. If it doesn't work even with that, don't use N_m3u8DL-RE as muxer at all, download the tracks separated. Then check if they're properly decrypted. If they are, then simply use mkvtoolnix
Edit: in addition you should try with --use-shaka-packager as well your original commandLast edited by 2nHxWW6GkN1l916N3ayz8HQoi; 8th Oct 2024 at 02:25.
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Is the audio/video sync issue constant? For example there's a constant time difference between the 2? If yes, you can easily fix it by shifting using mkvtoolnix
Edit: also try the shaka packager solution and tell if it still crashes--[----->+<]>.++++++++++++.---.--------.
Shaka package works for me. Make sure you install it properly, don't just use the parameter --use
Also use [ code] ... [/code] tags to properly format commands without adding random spaces.
https://www.transfernow.net/dl/20241008urBA5fUMCode:N_m3u8DL-RE "https://gcp.blutv.com/5bd2f293ac08fb00066d2b88/outputs/629f22571aade80008c81c8f/v3/dash-0/output.mpd" --key 2837ebbdaf3457a890c4dfe00651613d:6364397245981d00a83dfddbe1490149 --key 4abe235985f65d899ddd445181091bff:dda0cb3e06b056ccbd3868e78f19d4dd --key bb145633e4ff565b92c29fa1b9ede12d:b43c56c860c6d43e0a1fe2497ca8d461 --key 002829c360d05835890aeb86b77e0fcf:c23706dd3c9d9e3cb56e2aca24cf7db6 --key 7b91b2045c0c5295be14ebfec9d805d6:dd60e5786eb63bcdd6ba6f1e98d71f2e --save-name movie1 -M format=mkv:muxer=mkvmerge --use-shaka-packager
error 503 N_m3u8DL-RE
By whs912km in forum Video Streaming DownloadingReplies: 11Last Post: 26th Sep 2024, 11:29 -
N_m3u8DL-RE ERROR: The 'div'
By ahmedani in forum Video Streaming DownloadingReplies: 8Last Post: 7th Sep 2024, 06:07 -
Failed attempt to download a DRM-free movie from cda.pl using N_m3u8DL-RE.
By PepeForEver in forum Video Streaming DownloadingReplies: 18Last Post: 15th May 2024, 06:57 -
N_m3u8DL-RE - Error 403
By stevepen1974 in forum Video Streaming DownloadingReplies: 9Last Post: 2nd May 2024, 06:28 -
N_m3u8dl-re error in windows 7 please help.
By kartik in forum Video Streaming DownloadingReplies: 19Last Post: 5th Sep 2023, 07:09
It took me a while, thank you, I solved the problem bro
