Hello, so I'm having troubles with Blu-Disc Studio Lite that I figured I would come here for input on. So I have a bluray ready to compile, got everything setup and stuff. But whenever I try to run Mux what ends up happening is I get this error.
Going from segment null to segment $show_top$
Setup thread starts.
java.io.IOException: Unable to create arrange images in mosaic C:\Users\chris\AppData\Local\Temp\$BDCCCD.tmp\Comp iled\m1.png
at com.hdcookbook.grin.mosaic.Mosaic.writeMosaicImage (Mosaic.java:249)
at com.hdcookbook.grin.mosaic.MosaicMaker.makeMosaics (MosaicMaker.java:376)
at com.hdcookbook.grin.compiler.GrinCompiler.optimize Shows(GrinCompiler.java:93)
at com.hdcookbook.grin.binaryconverter.Main.convert(M ain.java:323)
at com.hdcookbook.grin.binaryconverter.Main.main(Main .java:241)
2:48:32 AM - [ERROR]
2:48:32 AM - [state] java -Xmx1024M -jar grincompiler.jar
I asked my brother who uses the software and he's never had this happened. I don't know if its something obvious I'm missing (hoping it is because it will be easy fix) but I figured I at least for help on it. What do you all make of this? Is there a mistake I'm making?
Thank you
Hello,
Usually such error happens when you are using a lot of images. Image buffer is limited to 5,9 Mpx in profile 1 and 8,0 Mpx in profile 2. Error handling is not perfect in Lite, so it just shows what grin compiler returns.
Please do not use full screen images. If this is a main menu background - render it into the background video. And check FAQ -> "How to reduce the amount of graphics" in the help https://blu-disc.net/download/help.zip
Error in Blu Disc Studio Lite
By MSFilms in forum Authoring (Blu-ray)Replies: 9Last Post: 9th Jun 2024, 21:17 -
Export into 5.1 audio with Pinnacle Studio 21.
By Seek&Create in forum AudioReplies: 0Last Post: 29th Apr 2024, 14:17 -
By calbear94 in forum Authoring (Blu-ray)Replies: 2Last Post: 6th Mar 2023, 20:45 -
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 22:18 -
Blu Ray blank disc issue - disc or writer?
By Damirko1981 in forum MediaReplies: 1Last Post: 10th Oct 2019, 13:44
