I've seen that , for .AVI files, I should be able to right-click, then 'properties', then 'summary' tab, then look at 'details' to see the frame rate, length, etc..
When I do that though, none of those items are there....
only 'Description' and 'Origin' , with levels under them.
Is there some other way to determine avi type?
TIA, Guys
[/img]
use VirtualDub, open file & get properties. PAL will generally be 25 frames/sec (fps) and NTSC 29.97 (NTSC film 23.976). Other frame rates are possible but nonstandard. For files that are VideoCD MPEG1 the dimensions will be 352x240 NTSC (both flavors) and 352x288 PAL.
The guides at left will help you identify the AVI based on what VirtualDub reports are the characteristics.
25 PAL to 23.976 NTSC AVI
By Nedward Orton in forum Video ConversionReplies: 8Last Post: 24th Mar 2012, 09:56 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Is this AVI PAL or NTSC?
By RedPenguin in forum Video ConversionReplies: 6Last Post: 25th Feb 2011, 21:17 -
Determining Whether a VHS is NTSC or PAL
By innocenceisdeath in forum RestorationReplies: 5Last Post: 28th Jun 2010, 03:45 -
PAL , NTSC in AVI
By anirban in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2008, 06:28
