Hi, I'm working with a mp4 video originally from a livestream, that plays the first three minutes normally then only plays audio. I've had some luck using the ffmpeg setpts filter as I end up with video that lasts 68 minutes of the 73 minutes of audio. However, this results in a desync between video and audio that starts early in the video, and builds throughout. The original video has some duplicate frames as a result of frame drops when originally streamed but I don't see these duplicate frames in the output video from ffmpeg. I'm unsure if the setpts filter is dropping these frames or some other issue is apparent. I'm not experienced with using ffmpeg/trying to fix videos so let me know if there is any more detail I can provide.
Not sure if helpful but here is basic info from ffmpeg
Code:ffmpeg version 2024-08-18-git-7e5410eadb-essentials_build-www.gyan.dev Copyright (c) 2000-2024 the FFmpeg developers built with gcc 13.2.0 (Rev5, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-zlib --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-sdl2 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-libfreetype --enable-libfribidi --enable-libharfbuzz --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-dxva2 --enable-d3d11va --enable-d3d12va --enable-ffnvcodec --enable-libvpl --enable-nvdec --enable-nvenc --enable-vaapi --enable-libgme --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libtheora --enable-libvo-amrwbenc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-librubberband libavutil 59. 34.100 / 59. 34.100 libavcodec 61. 11.100 / 61. 11.100 libavformat 61. 5.101 / 61. 5.101 libavdevice 61. 2.100 / 61. 2.100 libavfilter 10. 2.102 / 10. 2.102 libswscale 8. 2.100 / 8. 2.100 libswresample 5. 2.100 / 5. 2.100 libpostproc 58. 2.100 / 58. 2.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'input.mp4': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2avc1mp41 encoder : Lavf58.26.101 Duration: 01:13:34.85, start: 0.000000, bitrate: 1042 kb/s Stream #0:0[0x1](und): Video: h264 (Baseline) (avc1 / 0x31637661), yuv420p(progressive), 1280x720, 20969 kb/s, 623.94 fps, 29.97 tbr, 90k tbn (default) Metadata: handler_name : VideoHandler vendor_id : [0][0][0][0] Stream #0:1[0x2](und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, mono, fltp, 97 kb/s (default) Metadata: handler_name : SoundHandler vendor_id : [0][0][0][0] At least one output file must be specified
And the frame logs to the input and output videos (too long to post directly).
Results 1 to 1 of 1
How to fix subtitles that are out of sync with video
By flexmcmurphy in forum SubtitleReplies: 11Last Post: 30th Sep 2024, 22:05 -
Is there a way to take PTS/DTS from one video and apply them to another?
By Cyrax9 in forum MacReplies: 0Last Post: 19th Aug 2024, 18:16 -
How do I fix out of sync video and audio in my stream copied video?
By Guernsey in forum Newbie / General discussionsReplies: 3Last Post: 13th Jun 2024, 16:11 -
AVIDemux Help: How do you fix a stream copied video that goes out of sync?
By Guernsey in forum EditingReplies: 6Last Post: 14th Oct 2021, 14:54 -
How can I fix audio to video sync issues?
By sarit1 in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2021, 12:33
