Almost all my files I have are .avi and when I burn them some work fine but others you can only hear the audio but you can't see any video???
I use Nero to burn my VCD's.
Anyone know how I can make the video appear as well???
Explain in more detail exactly what you did with the avi file!
Does it play fine in wmp or some other software player?
What guide did you use?
If we start there I may be able to help you
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
Yes I can play them on wmp. I can also play them on divx.
I really dont know what to do, I'm new to this. I didn't use any guides. -
When you convert these avi files are you only using Nero?
If so try this guide http://www.vcdhelp.com/divxtovcd.htm
I follow the guide and at the end I burn with NEO instead of vcd easy
Give this guide a try ad let me know if I can help you further
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 12:50 -
Burning a AVI file onto a DVD, but there's No Audio--Need Help
By PacMan3000 in forum AudioReplies: 3Last Post: 4th Jul 2009, 17:03 -
Burning .avi with AC3 audio on Mac
By Munitalpa in forum MacReplies: 3Last Post: 22nd Aug 2007, 01:18 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23 -
choppy video/audio in AVI to DVD burning
By spanish in forum Authoring (DVD)Replies: 4Last Post: 15th May 2007, 13:10
