Does somebody know, why TMPGEnc or MGI VideoWave (Ligos based)
MPEG-2 encoders are limited to 8000kbs video bit rate despite the
DVD standard, that says every DVD player MUST support at least
9800kbs video bitrate?
BTW, not all MPEG-2 encoders have such limitation. For example, Ulead
Video Studio 6 (MainConcept based) encoder gives you up to 9800 if you
want produce DVD compatible MPEG-2 or, even, more if you do not care
about compatibility.
Dont know about Ligos, but TMPGenc is certainly not limited to 8000kbs bitrate for DVD. It will go much higher. Just load unlock.mcf and set whatever value you want. 8000kbps is only the value in the template, this allows space within the 9.8Mbps DVD limit for audio and extras such as subtitles.
An AVStoDVD non-starter (file-system limitation)
By Seeker47 in forum Video ConversionReplies: 9Last Post: 24th Nov 2010, 11:53 -
TV output with SANYO VPC-FH1 limitation
By pjandreu in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Jun 2010, 19:29 -
Noob:Philips 5990 WMV resolution limitation??
By peggypwr1 in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2009, 03:28 -
Is There A File Size Limitation to Convert .ts?
By toddon14th in forum Newbie / General discussionsReplies: 6Last Post: 17th Jun 2008, 00:04 -
DVDRecorder combo: bad qual recording: Defect or unit limitation: edited
By redraif in forum Newbie / General discussionsReplies: 0Last Post: 12th Jul 2007, 21:50
