I've had no issues with Amarec for the past week, capturing VHS with GV-USB2. However after starting up my PC and Amarec, the video comes through fine, but the audio is a static mess (see attached).
Any idea what's causing this? I'm thinking it's the GV-USB2 driver![]()
The attached does not show anything. Post a real audio+video captured file (the blue screens are not in video/audio specs and are not relevant)
Do you have the report file from AmarecTV? (you should always enable its creation)
It seems to be a bad tape or a VCR problem. Eventualy try VirtualDub to exclude software bad setting. And try to see if a direct VCR-TV connection shows the same issues. -
Same issue on virtualdub, so I then tried the Hauppauge USB-Live2 device, which delivered audio and video correctly. So not a VCR issue.
I tried the GV-USB2 again and it's working. No idea what happened, if it's the hardware or device drivers. Feels like something funky with the USB-Live2, but resolved now
I've found others have a similar issue with GV-USB2, their audio sounds quite similar:
https://www.youtube.com/watch?v=BECWzkRzwEQ
https://www.youtube.com/watch?v=J0VLK_DtYa4 -
It appears to be digital audio glitches probably driver related, Interference with the system audio drivers during monitoring while capturing, vdub should not exhibit this problem since it does have the option to turn off audio monitoring.
I do not know what's wrong with your GV-USB2, but if you have the Hauppauge USB-Live 2 and a Y/C signal path, just use that, it's even better
Amarec FPS issue
By Slothrop in forum Capturing and VCRReplies: 11Last Post: 13th Dec 2023, 09:50 -
Histogram for Amarec TV
By Alwyn in forum Capturing and VCRReplies: 15Last Post: 3rd May 2023, 09:05 -
Random Dropped Frames - How to fix or Amarec/Vdub alternatives?
By ENunn in forum Capturing and VCRReplies: 0Last Post: 13th Sep 2021, 01:12 -
Pulling my hair out on deinterlacing from Amarec..
By ugzz in forum Capturing and VCRReplies: 30Last Post: 14th Aug 2020, 10:39 -
Amarec frame rate warning
By itm2 in forum Capturing and VCRReplies: 1Last Post: 28th Jun 2020, 11:02
