Results 1 to 12 of 12
  1. Hi friends, I am trying to obtain the .
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Video URL?
  3. Did not think that people still had challenges with pssh. There are numerous threads that discuss this issue.
    Looking at your first pssh
    AAAAYXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAEEIARIQ2HZYMzRjTP+oc/eAqdLhmRoFQ29uYXgiJGQ3ZDE3NDVkLWMxNTYtNGNlOS1hN2M5LWIwMTUyZGEwZjIyYg==
    This decodes to
    Widevine Pssh
    "algorithm":"AESCTR",
    "keyIds":["2HZYMzRjTP+oc/eAqdLhmQ=="],
    "provider":"Conax",
    "contentId":"ZDdkMTc0NWQtYzE1Ni00Y2U5LWE3YzktYjAxN TJkYTBmMjJi"
    The second pssh is totally incorrect. [AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISENh2WD M0Y0z/qHP3gKnS4Zk=]
    You seem to have the correct pssh [first one]. Now you need the license server url plus the curl or fetch of the call. There are also numerous threads discussing this.
    Keep reading and learning. Start with the stickies especially the ones by Angela.
  4. Originally Posted by Gromyko View Post
    This decodes to
    Widevine Pssh
    "provider":"Conax",
    Yes, the first one is correct but the problem is that I have 3 more mpd and I can't get the correct pssh. and if I try to get through the kid they are not correct
  5. AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISENh2WD M0Y0z/qHP3gKnS4Zk=
    PSSH Box v0
    System ID: Widevine edef8ba9-79d6-4ace-a3c8-27dcd51d21ed
    PSSH Data (size: 18):
    Widevine Data:
    Key IDs (1):
    d8765833-3463-4cff-a873-f780a9d2e199
  6. Originally Posted by LZAA View Post
    PSSH Box v0
    Widevine Data:
    Key IDs (1):
    That pssh doesn't work, it's not the original. I'm looking for a way to get it without having to access the account, I have 3 mpd and the license, I need the original pssh to get the keys through pywidevine.
  7. Originally Posted by aletaladro View Post
    PSSH Box v0
    Widevine Data:
    Key IDs (1):
    duplicate reply
  8. Originally Posted by aletaladro View Post
    PSSH Box v0
    Widevine Data:
    Key IDs (1):
    if your license URL doesn't contain token or something, then you probably need to login to get other parameters
  9. Originally Posted by z1269925944 View Post
    PSSH Box v0
    Widevine Data:
    Key IDs (1):
    only license and pssh is needed to get the keys, the only problem is the pssh I only get wrong pssh
  10. Originally Posted by aletaladro View Post
    PSSH Box v0
    Widevine Data:
    Key IDs (1):
    based on "provider":"Conax", I highly doubt you only need license URL, I bet they have pre authorization variables just like trimi
  11. Originally Posted by z1269925944 View Post
    PSSH Box v0
    Widevine Data:
    Key IDs (1):
    I already obtained a key only with a license, trimi has nothing to do with this issue, it is very different
  12. Originally Posted by aletaladro View Post
    PSSH Box v0
    Widevine Data:
    Key IDs (1):
    ok then good luck with the rest of it.
