    Jun 2022
    india
    i need a process of getting keys from a app ..
    got mpd,pssh,licurl but the lic url is shortlived so anyone could get the keys pls dm discord killua3645 i will generate new and give u and u can give me keys and hopefully how to get them.
    and it uses widevine drm
  2. Which app or platform are you trying to get the keys from?
    Jun 2022
    india
    prepladder
    Jun 2022
    india
    since the update i am not able to use my usual script to get keys.....lic url is unchanged then y i am not able to get keys
    Jun 2022
    india
    i need help in extracting wv keys from the Prepladder.. Only works on phone..
    My previous script isnt getting keys through keysdb.net...
    Tried pywidevine with curl but still it doesnt work...
    it has a custom challenge scheme and i dont know how to workaround with that one
    could anyone help me with that...
    https://files.videohelp.com/u/302782/dump.har
    Jun 2022
    india
    anyone i dont need a custom automation script...just manual is fine..got the pssh,lic url
    i will paste the pssh and curl for lic url...but lic url expires in 5 minutes
    AAAAonBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAIIIARIQNe HmMAKWzF5NJTqHEIQDChoMaW5rYWVudHdvcmtzIlpuZWV0LXBn LWRyLXNvdW1lbi1tYW5uYS0xMDgwLWxpdmUtdmVyc2lvbi02LW dlbmVyYWwtcGh5aXNvbG9neS1uZXctcnItNi0wLWhpbmRpOTgx MTQtOTAxMjkqAkhE
    https://drm-bot.herokuapp.com/66fa6a3b98c50.txt ...this contains curl
